BaseVisual< T > Class Template Referenceabstract
#include <BaseVisual.hh>
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
 BaseVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)=0
virtual bool DetachGeometry (GeometryPtr _geometry)=0
virtual GeometryStorePtr Geometries () const =0
◆ BaseVisual()
BaseVisual
◆ ~BaseVisual()
~BaseVisual
◆ AddGeometry()
void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implements Visual.
◆ AttachGeometry()
protectedpure virtual
Implemented in Ogre2Visual, and OgreVisual.
void Destroy ( )
◆ DetachGeometry()
◆ Geometries()
◆ GeometryByIndex()
GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
Implements Visual.
◆ GeometryCount()
unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
Implements Visual.
◆ HasGeometry()
bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
Implements Visual.
◆ LocalPose()
math::Pose3d LocalPose ( ) const
Get the local pose.
The local pose
Implements Node.
MaterialPtr Material ( )
Implements Visual.
void PreRender ( )
Reimplemented in BaseGizmoVisual< OgreVisual >, and BaseGizmoVisual< Ogre2Visual >.
◆ PreRenderChildren()
◆ PreRenderGeometries()
◆ RemoveGeometries()
void RemoveGeometries ( )
Implements Visual.
◆ RemoveGeometry()
GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
Implements Visual.
◆ RemoveGeometryByIndex()
GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
Implements Visual.
◆ SetChildMaterial()
void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
◆ SetGeometryMaterial()
void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
Implements Visual.
◆ SetLocalPose()
void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implements Node.
◆ SetMaterial() [1/2]
bool  _unique = true
[in]_nameName of the material to be assigned
Implements Visual.
◆ SetMaterial() [2/2]
bool  _unique = true
Implements Visual.
◆ SetUserData()
void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
Implements Visual.
◆ SetVisible()
Implements Visual.
Reimplemented in Ogre2Visual, and OgreVisual.
◆ UserData()
Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Data associated with the key.
Implements Visual.
◆ material
◆ userData
std::map<std::string, Variant> userData
