Ogre2.x implementation of the visual class. More...
#include <Ogre2Visual.hh>
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~Ogre2Node ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Visual()
Ogre2Visual ( )
◆ ~Ogre2Visual()
virtual ~Ogre2Visual ( )
◆ AttachGeometry()
◆ DetachGeometry()
◆ Geometries()
Reimplemented from Ogre2Node.
Reimplemented in BaseGizmoVisual< Ogre2Visual >, BaseArrowVisual< Ogre2Visual >, and BaseAxisVisual< Ogre2Visual >.
◆ SetVisible()
Reimplemented from BaseVisual< Ogre2Node >.
◆ geometries
