#include <OgreVisual.hh>
virtual ~OgreVisual ()
virtual void SetVisible (bool _visible)
virtual ~BaseVisual ()
virtual MaterialPtr Material () override
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
virtual ~OgreNode ()
 OgreVisual ()
virtual bool AttachGeometry (GeometryPtr _geometry)
virtual bool DetachGeometry (GeometryPtr _geometry)
virtual GeometryStorePtr Geometries () const
virtual void Init ()
 BaseVisual ()
 OgreNode ()
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreVisual()
OgreVisual ( )
◆ ~OgreVisual()
virtual ~OgreVisual ( )
◆ AttachGeometry()
◆ DetachGeometry()
◆ Geometries()
◆ SetVisible()
Reimplemented from BaseVisual< OgreNode >.
◆ geometries
