#include <OgreNode.hh>
virtual ~OgreNode ()
 OgreNode ()
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreNode()
OgreNode ( )
◆ ~OgreNode()
virtual ~OgreNode ( )
◆ AttachChild()
◆ Children()
virtual NodeStorePtr Children ( ) const
Reimplemented from BaseNode< OgreObject >.
Reimplemented in OgreCamera, OgreThermalCamera, BaseVisual< OgreNode >, OgreGpuRays, and OgreLight.
◆ DetachChild()
virtual bool DetachChild ( NodePtr  _child)
◆ HasParent()
Implements Node.
◆ InheritScale()
True if this visual inherits scale from this parent
Implements Node.
◆ Load()
virtual void Load ( )
Reimplemented in BaseCamera< OgreSensor >.
◆ LocalScale()
The local scale
Implements Node.
◆ Node()
virtual Ogre::SceneNode* Node ( ) const
◆ Parent()
the parent Node
Implements Node.
◆ RawLocalPose()
◆ RawLocalPosition()
virtual math::Vector3d RawLocalPosition ( ) const
◆ RawLocalRotation()
virtual math::Quaterniond RawLocalRotation ( ) const
◆ SetInheritScale()
[in]_inheritTrue if this visual inherits scale from its parent
Implements Node.
◆ SetLocalScaleImpl()
Implements BaseNode< OgreObject >.
◆ SetParent()
virtual void SetParent ( OgreNodePtr  _parent)
◆ SetRawLocalPose()
virtual void SetRawLocalPose ( const math::Pose3d &  _Pose3d)
◆ SetRawLocalPosition()
virtual void SetRawLocalPosition ( const math::Vector3d &  _position)
◆ SetRawLocalRotation()
virtual void SetRawLocalRotation ( const math::Quaterniond &  _rotation)
◆ children
◆ ogreNode
Ogre::SceneNode* ogreNode = nullptr
◆ parent
OgreNodePtr parent
