#include <OgreLight.hh>
virtual ~OgreLight ()
virtual double AttenuationConstant () const
virtual double AttenuationLinear () const
virtual double AttenuationQuadratic () const
virtual double AttenuationRange () const
virtual bool CastShadows () const
virtual void Destroy ()
virtual math::Color DiffuseColor () const
virtual void SetAttenuationConstant (double _value)
virtual void SetAttenuationLinear (double _value)
virtual void SetAttenuationQuadratic (double _value)
virtual void SetAttenuationRange (double _range)
virtual void SetCastShadows (bool _castShadows)
virtual void SetDiffuseColor (const math::Color &_color)
virtual void SetSpecularColor (const math::Color &_color)
virtual math::Color SpecularColor () const
virtual ~BaseLight ()
virtual ~Light ()
virtual ~OgreNode ()
 OgreLight ()
virtual void Init ()
 BaseLight ()
 OgreNode ()
double attenConstant
double attenLinear
double attenQuadratic
double attenRange
Ogre::Light * ogreLight
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLight()
OgreLight ( )
◆ ~OgreLight()
virtual ~OgreLight ( )
◆ AttenuationConstant()
Implements Light.
◆ AttenuationLinear()
The attenuation linear value
Implements Light.
◆ AttenuationQuadratic()
Implements Light.
◆ AttenuationRange()
The attenuation range
Implements Light.
◆ CastShadows()
Implements Light.
Reimplemented from OgreNode.
◆ DiffuseColor()
The diffuse color
Implements Light.
◆ Light()
virtual Ogre::Light* Light ( ) const
◆ SetAttenuationConstant()
Implements BaseLight< OgreNode >.
◆ SetAttenuationLinear()
◆ SetAttenuationQuadratic()
◆ SetAttenuationRange()
◆ SetCastShadows()
◆ SetDiffuseColor()
[in]_colorNew diffuse color
◆ SetSpecularColor()
[in]_colorNew specular color
◆ SpecularColor()
The specular color
Implements Light.
◆ attenConstant
◆ attenLinear
double attenLinear
◆ attenQuadratic
◆ attenRange
double attenRange
◆ ogreLight
Ogre::Light* ogreLight
◆ ogreLightType
