Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the grid becomes 3D.
More...
| virtual | ~Grid () |
| | Destructor. More...
| virtual unsigned int | CellCount () const =0 |
| | Get the number of cells on a planar grid. More...
| virtual double | CellLength () const =0 |
| | Get the cell length. More...
| virtual void | SetCellCount (const unsigned int _count)=0 |
| | Set the number of cells on a planar grid. More...
| virtual void | SetCellLength (const double _len)=0 |
| | Set the cell length in one direction. The cells are assumed to be square. More...
| virtual void | SetVerticalCellCount (const unsigned int _count)=0 |
| | Set the vertical cell count of the grid. This makes the grid 3D. More...
| virtual unsigned int | VerticalCellCount () const =0 |
| | Get the vertical cell count. More...
| virtual | ~Geometry () |
| | Deconstructor. More...
| | Determine if this Geometry is attached to a Visual. More...
| | Get the material of this geometry. More...
| virtual VisualPtr | Parent () const =0 |
| | Get the parent Visual. More...
| | Detach this Geometry from its parent Visual. If this Geometry does not have a parent, no work will be done. More...
| | Set the materials of this Geometry. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
| | Set the materials of this Geometry. More...
| | Destructor. More...
