#include <BaseGrid.hh>
virtual | ~BaseGrid () |
Destructor. More... | |
virtual unsigned int | CellCount () const |
Get the number of cells on a planar grid. More... | |
virtual double | CellLength () const |
Get the cell length. More... | |
virtual void | Destroy () |
virtual void | PreRender () |
virtual void | SetCellCount (const unsigned int _count) |
Set the number of cells on a planar grid. More... | |
virtual void | SetCellLength (const double _len) |
Set the cell length in one direction. The cells are assumed to be square. More... | |
virtual void | SetVerticalCellCount (const unsigned int _count) |
Set the vertical cell count of the grid. This makes the grid 3D. More... | |
virtual unsigned int | VerticalCellCount () const |
Get the vertical cell count. More... | |
virtual | ~Grid () |
virtual | ~Geometry () |
Deconstructor. More... | |
virtual bool | HasParent () const =0 |
Determine if this Geometry is attached to a Visual. More... | |
virtual MaterialPtr | Material () const =0 |
Get the material of this geometry. More... | |
virtual VisualPtr | Parent () const =0 |
Get the parent Visual. More... | |
virtual void | RemoveParent ()=0 |
Detach this Geometry from its parent Visual. If this Geometry does not have a parent, no work will be done. More... | |
virtual void | SetMaterial (const std::string &_name, bool _unique=true)=0 |
Set the materials of this Geometry. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More... | |
virtual void | SetMaterial (MaterialPtr _material, bool _unique=true)=0 |
Set the materials of this Geometry. More... | |
virtual | ~Object () |
BaseGrid () | |
Constructor. More... | |
Protected Attributes | |
unsigned int | cellCount = 10u |
Number of cells in grid. More... | |
double | cellLength = 1.0 |
Length of a single cell. More... | |
bool | gridDirty = false |
Flag to indicate grid properties have changed. More... | |
double | heightOffset = 0.0 |
vertical offset of the XY plane from origin More... | |
unsigned int | verticalCellCount = 0 |
Number of cells in vertical direction. More... | |
template<class T>
class ignition::rendering::BaseGrid< T >
◆ BaseGrid()
protected |
◆ ~BaseGrid()
virtual |
◆ CellCount()
virtual |
◆ CellLength()
virtual |
◆ Destroy()
virtual |
◆ PreRender()
virtual |
◆ SetCellCount()
virtual |
◆ SetCellLength()
virtual |
[in] _len The cell length
Implements Grid.
◆ SetVerticalCellCount()
virtual |
[in] _count Number of cells in vertical direction.
Implements Grid.
◆ VerticalCellCount()
virtual |
◆ cellCount
protected |
◆ cellLength
protected |
◆ gridDirty
protected |
◆ heightOffset
protected |
◆ verticalCellCount
protected |
