Ogre2Grid Class Reference
Ogre2 implementation of a grid geometry. More...
#include <Ogre2Grid.hh>
virtual | ~Ogre2Grid () |
Destructor. More... | |
virtual void | Init () |
virtual MaterialPtr | Material () const |
Get the material of this geometry. More... | |
virtual Ogre::MovableObject * | OgreObject () const |
Get the ogre object representing this geometry. More... | |
virtual void | PreRender () |
virtual void | SetMaterial (MaterialPtr _material, bool _unique) |
Set the materials of this Geometry. More... | |
virtual | ~BaseGrid () |
virtual unsigned int | CellCount () const |
Get the number of cells on a planar grid. More... | |
virtual double | CellLength () const |
Get the cell length. More... | |
virtual void | Destroy () |
virtual void | SetCellCount (const unsigned int _count) |
Set the number of cells on a planar grid. More... | |
virtual void | SetCellLength (const double _len) |
Set the cell length in one direction. The cells are assumed to be square. More... | |
virtual void | SetVerticalCellCount (const unsigned int _count) |
Set the vertical cell count of the grid. This makes the grid 3D. More... | |
virtual unsigned int | VerticalCellCount () const |
Get the vertical cell count. More... | |
virtual | ~Grid () |
virtual unsigned int | CellCount () const =0 |
virtual double | CellLength () const =0 |
virtual unsigned int | VerticalCellCount () const =0 |
virtual | ~Geometry () |
Deconstructor. More... | |
virtual | ~Object () |
virtual | ~Ogre2Geometry () |
virtual bool | HasParent () const override |
Determine if this Geometry is attached to a Visual. More... | |
virtual VisualPtr | Parent () const override |
Get the parent Visual. More... | |
virtual | ~BaseGeometry () |
virtual VisualPtr | Parent () const override=0 |
virtual void | RemoveParent () override |
Detach this Geometry from its parent Visual. If this Geometry does not have a parent, no work will be done. More... | |
virtual void | SetMaterial (const std::string &_material, bool _unique=true) override |
Set the materials of this Geometry. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More... | |
virtual | ~Ogre2Object () |
virtual ScenePtr | Scene () const override |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
Ogre2Grid () | |
Constructor. More... | |
virtual void | SetMaterialImpl (Ogre2MaterialPtr _material) |
Set material to grid geometry. More... | |
BaseGrid () | |
Ogre2Geometry () | |
virtual void | SetParent (Ogre2VisualPtr _parent) |
Set the parent of this ogre geometry. More... | |
BaseGeometry () | |
Ogre2Object () | |
BaseObject () | |
virtual void | Load () |
unsigned int | cellCount |
Number of cells in grid. More... | |
double | cellLength |
Length of a single cell. More... | |
bool | gridDirty |
Flag to indicate grid properties have changed. More... | |
double | heightOffset |
vertical offset of the XY plane from origin More... | |
unsigned int | verticalCellCount |
Number of cells in vertical direction. More... | |
Ogre2VisualPtr | parent |
Parent visual. More... | |
Ogre2ScenePtr | scene |
Pointer to the ogre scene. More... | |
unsigned int | id |
std::string | name |
◆ Ogre2Grid()
protected |
◆ ~Ogre2Grid()
virtual |
◆ Init()
virtual |
◆ Material()
virtual |
◆ OgreObject()
virtual |
- Returns
- Pointer to an ogre movable object
Implements Ogre2Geometry.
◆ PreRender()
virtual |
Reimplemented from BaseGrid< Ogre2Geometry >.
◆ SetMaterial()
virtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Ogre material.
