BaseGeometry< T > Class Template Referenceabstract
#include <BaseGeometry.hh>
virtual ~BaseGeometry ()
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 BaseGeometry ()
◆ BaseGeometry()
BaseGeometry
◆ ~BaseGeometry()
~BaseGeometry
void Destroy ( )
Reimplemented in BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, OgreMarker, Ogre2Marker, Ogre2Mesh, OgreMesh, BaseMarker< Ogre2Geometry >, BaseMarker< OgreGeometry >, BaseText< OgreGeometry >, BaseGrid< Ogre2Geometry >, and BaseGrid< OgreGeometry >.
◆ Parent()
overridepure virtual
the parent Visual
Implements Geometry.
◆ RemoveParent()
void RemoveParent ( )
◆ SetMaterial() [1/2]
bool  _unique = true
Reimplemented in BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, OgreText, OgreMarker, Ogre2Marker, OgreGrid, and Ogre2Grid.
