Base implementation of a text geometry. More...
#include <BaseText.hh>
virtual ~BaseText ()
virtual gz::math::AxisAlignedBox AABB () const override
virtual float Baseline () const override
virtual float CharHeight () const override
virtual gz::math::Color Color () const override
 Get the text color. More...
std::string FontName () const override
 Get the font name. More...
virtual TextHorizontalAlign HorizontalAlignment () const override
virtual void SetBaseline (const float _baseline) override
virtual void SetCharHeight (const float _height) override
virtual void SetColor (const gz::math::Color &_color) override
 Set the text color. More...
void SetFontName (const std::string &_font) override
 Set the font. More...
void SetShowOnTop (const bool _onTop) override
 True = text always is displayed ontop. More...
virtual void SetSpaceWidth (const float _width) override
virtual void SetTextAlignment (const TextHorizontalAlign &_hAlign, const TextVerticalAlign &_vAlign) override
virtual void SetTextString (const std::string &_text) override
virtual bool ShowOnTop () const override
virtual float SpaceWidth () const override
virtual std::string TextString () const override
virtual TextVerticalAlign VerticalAlignment () const override
- Public Member Functions inherited from Text
 Text ()=default
virtual ~Text ()=default
 BaseText ()
float baseline = 0
 Baseline height in meters. More...
float charHeight = 1.0
 Character height in meters. More...
gz::math::Color color = gz::math::Color::White
 Text color. More...
std::string fontName = "Liberation Sans"
 Font name, such as "Liberation Sans". More...
TextHorizontalAlign horizontalAlign
 Horizontal alignment. More...
bool onTop = false
 True for text to be displayed on top of other objects in the scene. More...
float spaceWidth = 0
 Width of space between letters. More...
std::string text
 Text being displayed. More...
bool textDirty = false
 Flag to indicate text properties have changed. More...
TextVerticalAlign verticalAlign = TextVerticalAlign::BOTTOM
 Vertical alignment. More...
template<class T>
class ignition::rendering::BaseText< T >
◆ BaseText()
BaseText
◆ ~BaseText()
~BaseText
◆ AABB()
gz::math::AxisAlignedBox AABB ( ) const
Implements Text.
◆ Baseline()
float Baseline ( ) const
Baseline height
SetBaseline()
Implements Text.
◆ CharHeight()
float CharHeight ( ) const
SetCharHeight()
Implements Text.
◆ Color()
gz::math::Color Color ( ) const
Get the text color.
Text color.
SetColor()
Implements Text.
void Destroy ( )
◆ FontName()
std::string FontName ( ) const
Get the font name.
The font name.
SetFontName()
Implements Text.
◆ HorizontalAlignment()
TextHorizontalAlign HorizontalAlignment ( ) const
Text horizontal alignment
Implements Text.
void PreRender ( )
Reimplemented in OgreText.
◆ SetBaseline()
void SetBaseline ( const float  _baseline)
[in]_baselineBaseline height
Baseline()
Implements Text.
◆ SetCharHeight()
void SetCharHeight ( const float  _height)
CharHeight()
Implements Text.
◆ SetColor()
void SetColor ( const gz::math::Color &  _color)
Set the text color.
[in]_colorText color.
Color()
Implements Text.
◆ SetFontName()
void SetFontName ( const std::string &  _font)
Set the font.
[in]_fontName of the font
FontName()
Implements Text.
◆ SetShowOnTop()
void SetShowOnTop ( const bool  _onTop)
ShowOnTop()
Implements Text.
◆ SetSpaceWidth()
void SetSpaceWidth ( const float  _width)
[in]_widthSpace width
SpaceWidth()
Implements Text.
◆ SetTextAlignment()
void SetTextAlignment ( const TextHorizontalAlign &  _hAlign,
[in]_vAlignVertical alignment
Implements Text.
◆ SetTextString()
void SetTextString ( const std::string &  _text)
[in]_textThe text to display.
Text()
Implements Text.
◆ ShowOnTop()
bool ShowOnTop ( ) const
True if it is on top.
SetShowOnTop()
Implements Text.
◆ SpaceWidth()
float SpaceWidth ( ) const
Space width
SetSpaceWidth()
Implements Text.
◆ TextString()
std::string TextString ( ) const
The displayed text.
SetText()
Implements Text.
◆ VerticalAlignment()
TextVerticalAlign VerticalAlignment ( ) const
Text verical alignment
Implements Text.
◆ baseline
float baseline = 0
◆ charHeight
◆ color
Text color.
◆ fontName
◆ horizontalAlign
Initial value:
◆ onTop
bool onTop = false
◆ spaceWidth
◆ text
std::string text
◆ textDirty
◆ verticalAlign
Vertical alignment.
