Ogre implementation of text geometry. More...
#include <OgreText.hh>
virtual ~OgreText ()
virtual gz::math::AxisAlignedBox AABB () const override
virtual void SetBaseline (const float _baseline) override
virtual void SetCharHeight (const float _height) override
virtual void SetColor (const gz::math::Color &_color) override
 Set the text color. More...
virtual void SetFontName (const std::string &_font) override
 Set the font. More...
virtual void SetShowOnTop (const bool _onTop) override
 True = text always is displayed ontop. More...
virtual void SetSpaceWidth (const float _width) override
virtual void SetTextAlignment (const TextHorizontalAlign &_horizAlign, const TextVerticalAlign &_vertAlign) override
virtual void SetTextString (const std::string &_text) override
- Public Member Functions inherited from BaseText< OgreGeometry >
virtual ~BaseText ()
virtual float Baseline () const override
virtual float CharHeight () const override
virtual gz::math::Color Color () const override
 Get the text color. More...
std::string FontName () const override
 Get the font name. More...
virtual TextHorizontalAlign HorizontalAlignment () const override
virtual bool ShowOnTop () const override
virtual float SpaceWidth () const override
virtual std::string TextString () const override
virtual TextVerticalAlign VerticalAlignment () const override
- Public Member Functions inherited from Text
 Text ()=default
virtual ~Text ()=default
virtual float Baseline () const =0
virtual float CharHeight () const =0
virtual gz::math::Color Color () const =0
virtual std::string FontName () const =0
virtual TextHorizontalAlign HorizontalAlignment () const =0
virtual bool ShowOnTop () const =0
virtual float SpaceWidth () const =0
virtual std::string TextString () const =0
virtual TextVerticalAlign VerticalAlignment () const =0
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 OgreText ()
 Set material to text geometry. More...
- Protected Member Functions inherited from BaseText< OgreGeometry >
 BaseText ()
 OgreGeometry ()
 BaseGeometry ()
- Protected Attributes inherited from BaseText< OgreGeometry >
float baseline
 Baseline height in meters. More...
float charHeight
 Character height in meters. More...
gz::math::Color color
 Text color. More...
std::string fontName
 Font name, such as "Liberation Sans". More...
TextHorizontalAlign horizontalAlign
 Horizontal alignment. More...
bool onTop
 True for text to be displayed on top of other objects in the scene. More...
float spaceWidth
 Width of space between letters. More...
std::string text
 Text being displayed. More...
bool textDirty
 Flag to indicate text properties have changed. More...
TextVerticalAlign verticalAlign
 Vertical alignment. More...
OgreVisualPtr parent
◆ OgreText()
OgreText ( )
◆ ~OgreText()
virtual ~OgreText ( )
◆ AABB()
virtual gz::math::AxisAlignedBox AABB ( ) const
Implements Text.
Implements Geometry.
◆ OgreObject()
Implements OgreGeometry.
Reimplemented from BaseText< OgreGeometry >.
◆ SetBaseline()
[in]_baselineBaseline height
Baseline()
◆ SetCharHeight()
CharHeight()
◆ SetColor()
virtual void SetColor ( const gz::math::Color &  _color)
Set the text color.
[in]_colorText color.
Color()
◆ SetFontName()
Set the font.
[in]_fontName of the font
FontName()
Implements Text.
◆ SetMaterial()
bool  _unique
◆ SetMaterialImpl()
[in]_materialOgre material.
◆ SetShowOnTop()
ShowOnTop()
Implements Text.
◆ SetSpaceWidth()
[in]_widthSpace width
SpaceWidth()
◆ SetTextAlignment()
[in]_vAlignVertical alignment
◆ SetTextString()
[in]_textThe text to display.
Text()
