#include <OgreGeometry.hh>
virtual ~OgreGeometry ()
virtual Ogre::MovableObject * OgreObject () const =0
virtual ~BaseGeometry ()
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 OgreGeometry ()
 BaseGeometry ()
virtual void Init ()
OgreVisualPtr parent
◆ OgreGeometry()
OgreGeometry ( )
◆ ~OgreGeometry()
virtual ~OgreGeometry ( )
◆ HasParent()
Implements Geometry.
◆ OgreObject()
Implemented in OgreMesh, OgreText, OgreMarker, and OgreGrid.
◆ Parent()
the parent Visual
◆ SetParent()
virtual void SetParent ( OgreVisualPtr  _parent)
◆ parent
