#include <OgreMesh.hh>
virtual ~OgreMesh ()
- Public Member Functions inherited from BaseMesh< OgreGeometry >
virtual ~BaseMesh ()
virtual ~Mesh ()
virtual unsigned int SubMeshCount () const =0
virtual ~OgreGeometry ()
virtual ~BaseGeometry ()
 OgreMesh ()
virtual SubMeshStorePtr SubMeshes () const override
- Protected Member Functions inherited from BaseMesh< OgreGeometry >
 BaseMesh ()
virtual SubMeshStorePtr SubMeshes () const=0
 OgreGeometry ()
 BaseGeometry ()
virtual void Init ()
Ogre::Entity * ogreEntity = nullptr
OgreSubMeshStorePtr subMeshes
- Protected Attributes inherited from BaseMesh< OgreGeometry >
bool ownsMaterial
OgreVisualPtr parent
◆ OgreMesh()
OgreMesh ( )
◆ ~OgreMesh()
virtual ~OgreMesh ( )
Reimplemented from BaseMesh< OgreGeometry >.
◆ HasSkeleton()
True if the mesh has skeleton
Implements Mesh.
◆ OgreObject()
Implements OgreGeometry.
  • Map holding:
    • Skeleton node names
True if all the transformations are set to the skeleton
◆ SkeletonLocalTransforms()
  • Map holding:
Implements Mesh.
◆ SubMeshes()
◆ ogreEntity
Ogre::Entity* ogreEntity = nullptr
◆ subMeshes
