Mesh Class Referenceabstract
Represents a collection of mesh geometries. More...
#include <ignition/rendering/Mesh>
virtual ~Mesh ()
virtual bool HasSkeleton () const =0
virtual bool HasSubMesh (ConstSubMeshPtr _subMesh) const =0
virtual bool HasSubMeshName (const std::string &_name) const =0
virtual void SetSkeletonLocalTransforms (const std::map< std::string, math::Matrix4d > &_tfs)=0
virtual std::map< std::string, math::Matrix4d > SkeletonLocalTransforms () const =0
virtual SubMeshPtr SubMeshByIndex (unsigned int _index) const =0
virtual SubMeshPtr SubMeshByName (const std::string &_name) const =0
virtual unsigned int SubMeshCount () const =0
◆ ~Mesh()
virtual ~Mesh ( )
inlinevirtual
◆ HasSkeleton()
True if the mesh has skeleton
Implemented in Ogre2Mesh, OgreMesh, and BaseMesh< T >.
◆ HasSubMesh()
virtual bool HasSubMesh ( ConstSubMeshPtr  _subMesh) const
[in]_subMeshSub-mesh in question
True if has given sub-mesh
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
◆ HasSubMeshName()
virtual bool HasSubMeshName ( const std::string &  _name) const
[in]_nameName of sub-mesh in question
True if has sub-mesh with given name
  • Map holding:
    • Skeleton node names
True if all the transformations are set to the skeleton
Implemented in Ogre2Mesh, OgreMesh, BaseMesh< T >, BaseMesh< Ogre2Geometry >, and BaseMesh< OgreGeometry >.
◆ SkeletonLocalTransforms()
  • Map holding:
◆ SubMeshByIndex()
virtual SubMeshPtr SubMeshByIndex ( unsigned int  _index) const
[in]_indexIndex of sub-mesh
The sub-mesh at the given index
◆ SubMeshByName()
virtual SubMeshPtr SubMeshByName ( const std::string &  _name) const
The sub-mesh with the given name
◆ SubMeshCount()
virtual unsigned int SubMeshCount ( ) const
The sub-mesh count
Implemented in BaseMesh< T >.
