virtual | ~Ogre2Geometry () |
| Destructor. More...
virtual bool | HasParent () const override |
| Determine if this Geometry is attached to a Visual. More...
virtual Ogre::MovableObject * | OgreObject () const =0 |
| Get the ogre object representing this geometry. More...
virtual VisualPtr | Parent () const override |
| Get the parent Visual. More...
virtual | ~BaseGeometry () |
virtual void | Destroy () override |
| Destroy any resources associated with this object. Invoking any other functions after destroying an object will result in undefined behavior. More...
virtual VisualPtr | Parent () const override=0 |
virtual void | RemoveParent () override |
| Detach this Geometry from its parent Visual. If this Geometry does not have a parent, no work will be done. More...
virtual void | SetMaterial (const std::string &_material, bool _unique=true) override |
| Set the materials of this Geometry. The specified material will be retrieved from the parent Scene. If no material is registered by the given name, no work will be done. More...
virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override=0 |
| Set the materials of this Geometry. More...
virtual | ~Geometry () |
| Deconstructor. More...
virtual MaterialPtr | Material () const =0 |
| Get the material of this geometry. More...
virtual | ~Object () |
| Destructor. More...
| Get the object ID. This ID will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. More...
| Get the object name. This name will be unique across all objects inside a given scene, but necessarily true for objects across different scenes. More...
| Post process this object and any of its children after rendering. More...
| Prepare this object and any of its children for rendering. This should be called for each object in a scene just before rendering, which can be achieved by a single call to Scene::PreRender. More...
| Get the Scene that created this object. More...
virtual | ~Ogre2Object () |
| Destructor. More...
virtual ScenePtr | Scene () const override |
virtual | ~BaseObject () |
virtual unsigned int | Id () const override |
virtual std::string | Name () const override |
virtual void | PostRender () override |
virtual void | PreRender () override |
Ogre2.x implementation of the geometry class.
