Generate depth ray data. More...
#include <ignition/rendering/GpuRays.hh>
Public Types | |
| virtual | ~GpuRays () |
| Destructor. More... | |
| virtual gz::math::Angle | AngleMax () const =0 |
| Get maximal horizontal angle value. More... | |
| virtual gz::math::Angle | AngleMin () const =0 |
| Get minimal horizontal angle value. More... | |
| virtual unsigned int | Channels () const =0 |
| Get the number of channels used to store the ray data. More... | |
| virtual bool | Clamp () const =0 |
| Get behaviour for data values outside of camera range. More... | |
| virtual common::ConnectionPtr | ConnectNewGpuRaysFrame (std::function< void(const float *_frame, unsigned int _width, unsigned int _height, unsigned int _depth, const std::string &)> _subscriber)=0 |
| Connect to a gpu rays frame signal. More... | |
| virtual void | Copy (float *_data)=0 |
| Copy to the specified memory direction the gpu rays data. More... | |
| virtual const float * | Data () const =0 |
| All things needed to get back z buffer for gpu rays data. More... | |
| virtual bool | IsHorizontal () const =0 |
| Gets if sensor is horizontal. More... | |
| virtual int | RangeCount () const =0 |
| Get hoizontal range count, i.e. ray count * horz resolution. More... | |
| virtual double | RangeCountRatio () const =0 |
| Get the ray count ratio (equivalent to aspect ratio) More... | |
| virtual int | RayCount () const =0 |
| Get horizontal quantity of rays. More... | |
| virtual double | RayCountRatio () const =0 |
| virtual void | SetAngleMax (double _angle)=0 |
| Set maximal horizontal angle value. More... | |
| virtual void | SetAngleMin (double _angle)=0 |
| Set minimal horizontal angle value. More... | |
| virtual void | SetClamp (const bool _clamp)=0 |
| Configure behaviour for data values outside of camera range. More... | |
| virtual void | SetIsHorizontal (const bool _horizontal)=0 |
| Set sensor horizontal or vertical. More... | |
| virtual void | SetRayCount (int _samples)=0 |
| Set horizontal quantity of rays. More... | |
| virtual void | SetRayCountRatio (const double _rayCountRatio)=0 |
| Sets the ray count ratio (equivalent to aspect ratio) More... | |
| virtual void | SetVerticalAngleMax (const double _angle)=0 |
| Set maximal vertical angle value. More... | |
| virtual void | SetVerticalAngleMin (const double _angle)=0 |
| Set minimal vertical angle value. More... | |
| virtual void | SetVerticalRayCount (int _samples)=0 |
| Set vertical quantity of rays. More... | |
| virtual gz::math::Angle | VerticalAngleMax () const =0 |
| Get maximal vertical angle value. More... | |
| virtual gz::math::Angle | VerticalAngleMin () const =0 |
| Get minimal vertical angle value. More... | |
| virtual int | VerticalRangeCount () const =0 |
| Get vertical range count, i.e. ray count * vert resolution. More... | |
| virtual int | VerticalRayCount () const =0 |
| Get vertical quantity of rays. More... | |
| virtual math::Angle | VFOV () const =0 |
| Get the vertical field-of-view. More... | |
| virtual | ~Camera () |
| Deconstructor. More... | |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
Member Typedef Documentation
◆ NewFrameListener
| typedef std::function<void(const void*, unsigned int, unsigned int, unsigned int, const std::string&)> NewFrameListener |
◆ ~GpuRays()
inlinevirtual |
◆ AngleMax()
pure virtual |
Implemented in BaseGpuRays< T >.
◆ AngleMin()
pure virtual |
◆ Channels()
pure virtual |
- Returns
- Channel count.
◆ Clamp()
pure virtual |
- Returns
- True if data values are clampped to camera clip distances,
◆ ConnectNewGpuRaysFrame()
pure virtual |
[in] _subscriber Callback that is called when a new image is generated. The callback function parameters are: _frame: Image frame is an array of floats. Size is equal to width * height * channels Each gpu rays reading occupies 3 floats Index 0: depth value Index 1: retro value Index 2: 0. Not used _width: Width of image, i.e. number of data in the horizonal scan _height: Height o image, i.e. number of scans in vertical direction _channels: Number of channels, i.e. 3 floats per gpu rays reading _format: Pixel format of the image frame.
- Returns
- A pointer to the connection. This must be kept in scope.
◆ Copy()
pure virtual |
Implemented in Ogre2GpuRays, OgreGpuRays, BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ Data()
pure virtual |
- Returns
- Array of gpu rays data.
Implemented in Ogre2GpuRays, OgreGpuRays, and BaseGpuRays< T >.
◆ IsHorizontal()
pure virtual |
- Returns
- True if horizontal, false if not
◆ RangeCount()
pure virtual |
◆ RangeCountRatio()
pure virtual |
- Returns
- The ray count ratio (equivalent to aspect ratio)
◆ RayCount()
pure virtual |
◆ RayCountRatio()
pure virtual |
- Returns
◆ SetAngleMax()
pure virtual |
Implemented in BaseGpuRays< T >, BaseGpuRays< Ogre2Sensor >, and BaseGpuRays< OgreSensor >.
◆ SetAngleMin()
pure virtual |
◆ SetClamp()
pure virtual |
[in] _clamp True to clamp data to camera clip distances,
◆ SetIsHorizontal()
pure virtual |
[in] _horizontal True if horizontal, false if not
◆ SetRayCount()
pure virtual |
◆ SetRayCountRatio()
pure virtual |
[in] _rayCountRatio ray count ratio (equivalent to aspect ratio)
◆ SetVerticalAngleMax()
pure virtual |
◆ SetVerticalAngleMin()
pure virtual |
◆ SetVerticalRayCount()
pure virtual |
◆ VerticalAngleMax()
pure virtual |
◆ VerticalAngleMin()
pure virtual |
◆ VerticalRangeCount()
pure virtual |
◆ VerticalRayCount()
pure virtual |
◆ VFOV()
pure virtual |
- Returns
- The vertical field of view of the gpu rays.
