GizmoVisual Class Referenceabstract
#include <ignition/rendering/GizmoVisual.hh>
virtual ~GizmoVisual ()
virtual math::Vector3d ActiveAxis () const =0
virtual TransformAxis AxisById (unsigned int _id) const =0
virtual VisualPtr ChildByAxis (unsigned int _axis) const =0
virtual TransformMode Mode () const =0
virtual void SetActiveAxis (const math::Vector3d &_axis)=0
virtual void SetTransformMode (TransformMode _mode)=0
virtual ~CompositeVisual ()
virtual MaterialPtr Material ()=0
 Store any custom data associated with this visual. More...
 Get custom data stored in this visual. More...
◆ ~GizmoVisual()
virtual ~GizmoVisual ( )
inlinevirtual
◆ ActiveAxis()
virtual math::Vector3d ActiveAxis ( ) const
Active axis
SetActiveAxis
Implemented in BaseGizmoVisual< T >.
◆ AxisById()
virtual TransformAxis AxisById ( unsigned int  _id) const
Implemented in BaseGizmoVisual< T >, BaseGizmoVisual< OgreVisual >, and BaseGizmoVisual< Ogre2Visual >.
◆ ChildByAxis()
virtual VisualPtr ChildByAxis ( unsigned int  _axis) const
TransformAxis, TransformMode
◆ Mode()
virtual TransformMode Mode ( ) const
Transform mode
SetTransformMode
◆ SetActiveAxis()
virtual void SetActiveAxis ( const math::Vector3d &  _axis)
◆ SetTransformMode()
virtual void SetTransformMode ( TransformMode  _mode)
GizmoMode
