gz/rendering/RenderEngine.hh
17 #ifndef GZ_RENDERING_RENDERENGINE_HH_
18 #define GZ_RENDERING_RENDERENGINE_HH_
20 #include <map>
21 #include <string>
22 #include "gz/rendering/config.hh"
24 #include "gz/rendering/Export.hh"
25
26 namespace ignition
27 {
28  namespace rendering
29  {
30  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
31  //
36  class IGNITION_RENDERING_VISIBLE RenderEngine
37  {
39  public: virtual ~RenderEngine() { }
40
46  public: virtual bool Load(
47  const std::map<std::string, std::string> &_params = {}) = 0;
48
52  public: virtual bool Init() = 0;
53
58  public: virtual void Destroy() = 0;
59
60  // TODO(anyone): merge with Destroy
61  public: virtual bool Fini() = 0;
62
65  public: virtual bool IsLoaded() const = 0;
66
69  public: virtual bool IsInitialized() const = 0;
70
75  public: virtual bool IsEnabled() const = 0;
76
79  public: virtual std::string Name() const = 0;
80
84  public: virtual unsigned int SceneCount() const = 0;
85
90  public: virtual bool HasScene(ConstScenePtr _scene) const = 0;
91
96  public: virtual bool HasSceneId(unsigned int _id) const = 0;
97
102  public: virtual bool HasSceneName(const std::string &_name) const = 0;
103
108  public: virtual ScenePtr SceneById(unsigned int _id) const = 0;
109
114  public: virtual ScenePtr SceneByName(
115  const std::string &_name) const = 0;
116
123  public: virtual ScenePtr SceneByIndex(unsigned int _index) const = 0;
124
128  public: virtual void DestroyScene(ScenePtr _scene) = 0;
129
133  public: virtual void DestroySceneById(unsigned int _id) = 0;
134
138  public: virtual void DestroySceneByName(const std::string &_name) = 0;
139
143  public: virtual void DestroySceneByIndex(unsigned int _index) = 0;
144
146  public: virtual void DestroyScenes() = 0;
147
154  public: virtual ScenePtr CreateScene(const std::string &_name) = 0;
155
163  public: virtual ScenePtr CreateScene(unsigned int _id,
164  const std::string &_name) = 0;
165
169  public: virtual void SetHeadless(bool _headless) = 0;
170
173  public: virtual bool Headless() const = 0;
174
177  public: virtual void AddResourcePath(const std::string &_path) = 0;
178
180  public: virtual RenderPassSystemPtr RenderPassSystem() const = 0;
181  };
182  }
183  }
184 }
185 #endif
Definition: gz/rendering/RenderEngine.hh:37
virtual void DestroySceneByName(const std::string &_name)=0
Destroy the scene with the given name. If no scenes exist with the given name, no work will be done.
Deconstructor.
Definition: gz/rendering/RenderEngine.hh:39
virtual void AddResourcePath(const std::string &_path)=0
Add path to media resource location.
virtual bool Init()=0
Initialize the render-engine. This should be called immediately after a successful call to Load.
virtual bool HasScene(ConstScenePtr _scene) const =0
Determine if the given scene is actively managed by this render-engine.
virtual RenderPassSystemPtr RenderPassSystem() const =0
Get the render pass system for this engine.
virtual bool HasSceneName(const std::string &_name) const =0
Determine if this render-engine manages a scene with the given name.
virtual bool IsInitialized() const =0
Determines if the render-engine has been initialized.
virtual bool Load(const std::map< std::string, std::string > &_params={})=0
Load any necessary resources to set up render-engine. This should called before any other function.
virtual ScenePtr CreateScene(const std::string &_name)=0
Create a new scene with the given name. The given name should be unique across all scenes managed by ...
virtual std::string Name() const =0
Get name of the render-engine.
virtual void DestroyScenes()=0
Destroy all scenes managed by this render-engine.
virtual unsigned int SceneCount() const =0
Get the number of scenes actively managed by this render-engine.
virtual void Destroy()=0
Destroys all scenes created by render-engine and releases all loaded resources. This should be called...
virtual bool HasSceneId(unsigned int _id) const =0
Determine if this render-engine manages a scene with the given ID.
virtual bool IsLoaded() const =0
Determines if the render-engine has been loaded.
virtual void SetHeadless(bool _headless)=0
Set headless mode Only available in OGRE 2.2, which makes use of EGL.
virtual ScenePtr SceneByName(const std::string &_name) const =0
Get the scene with the given name. If no scenes exist with the given name, NULL will be returned.
virtual void DestroyScene(ScenePtr _scene)=0
Destroy the given scene. If the given scene is not managed by this render-engine, no work will be don...
virtual ScenePtr SceneByIndex(unsigned int _index) const =0
Get the scene at the given index. If no scenes exist at the given index, NULL will be returned.
virtual ScenePtr CreateScene(unsigned int _id, const std::string &_name)=0
Create a new scene with the given ID. The given ID should be unique across all scenes managed by this...
virtual bool IsEnabled() const =0
Determines if the render-engine can be used. Despite loading and initializing the render-engine,...
virtual ScenePtr SceneById(unsigned int _id) const =0
Get the scene with the given ID. If no scenes exist with the given ID, NULL will be returned.
virtual void DestroySceneById(unsigned int _id)=0
Destroy the scene with the given ID. If no scenes exist with the given ID, no work will be done.
virtual bool Headless() const =0
Get headless mode.
virtual void DestroySceneByIndex(unsigned int _index)=0
Destroy the scene at the given index. If no scenes exist at the given index, no work will be done.
