gz/rendering/ogre2/Ogre2ParticleEmitter.hh
17 #ifndef IGNITION_RENDERING_OGRE2_OGRE2PARTICLEEMITTER_HH_
18 #define IGNITION_RENDERING_OGRE2_OGRE2PARTICLEEMITTER_HH_
20 #include <memory>
21 #include <string>
24
25 namespace ignition
26 {
27  namespace rendering
28  {
29  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
30  //
31  // Forward declaration
32  class Ogre2ParticleEmitterPrivate;
33
35  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2ParticleEmitter :
36  public BaseParticleEmitter<Ogre2Visual>
37  {
39  protected: Ogre2ParticleEmitter();
40
42  public: virtual ~Ogre2ParticleEmitter();
43
44  // Documentation inherited.
45  public: void Destroy() override;
46
47  // Documentation inherited.
48  public: virtual void SetType(const EmitterType _type) override;
49
50  // Documentation inherited.
51  public: virtual void SetEmitterSize(
52  const ignition::math::Vector3d &_size) override;
53
54  // Documentation inherited.
55  public: virtual void SetRate(double _rate) override;
56
57  // Documentation inherited.
58  public: virtual void SetDuration(double _duration) override;
59
60  // Documentation inherited.
61  public: virtual void SetEmitting(bool _enable) override;
62
63  // Documentation inherited.
64  public: virtual void SetParticleSize(
65  const ignition::math::Vector3d &_size) override;
66
67  // Documentation inherited.
68  public: virtual void SetLifetime(double _lifetime) override;
69
70  // Documentation inherited.
71  public: virtual void SetMaterial(const MaterialPtr &_material) override;
72
73  // Documentation inherited.
74  public: virtual void SetVelocityRange(double _minVelocity,
75  double _maxVelocity) override;
76
77  // Documentation inherited.
78  public: virtual void SetColorRange(
79  const ignition::math::Color &_colorStart,
80  const ignition::math::Color &_colorEnd) override;
81
82  // Documentation inherited.
83  public: virtual void SetScaleRate(double _scaleRate) override;
84
85  // Documentation inherited.
86  public: virtual void SetColorRangeImage(const std::string &_image)
87  override;
88
90  public: static const uint32_t kParticleVisibilityFlags;
91
92  // Documentation inherited.
93  protected: virtual void Init() override;
94
97  private: void PreRenderImpl();
98
100  private: void CreateParticleSystem();
101
103  private: friend class Ogre2Scene;
104
107  };
108  }
109  }
110 }
111 #endif
A base implementation of the ParticleEmitter class.
Definition: gz/rendering/base/BaseParticleEmitter.hh:40
Class to manage a particle emitter.
Definition: gz/rendering/ogre2/Ogre2ParticleEmitter.hh:37
virtual void SetEmitterSize(const ignition::math::Vector3d &_size) override
Set the size of the emitter where the particles are sampled. Default value is (1, 1,...
Particle system visibility flags.
Definition: gz/rendering/ogre2/Ogre2ParticleEmitter.hh:90
Set the number of seconds each particle will ’live’ for before being destroyed. Default value is 5.
Set the emitter type. Default value is EM_POINT.
virtual void SetColorRangeImage(const std::string &_image) override
Set the path to the color image used as an affector. This affector modifies the color of particles in...
virtual void SetVelocityRange(double _minVelocity, double _maxVelocity) override
Set a velocity range and each particle is emitted with a random velocity within this range (m/s)....
virtual void SetParticleSize(const ignition::math::Vector3d &_size) override
Set the particle dimensions (width, height, depth). Default value is {1, 1, 1}.
Set the number of seconds the emitter is active. A value of 0 means infinite duration....
Set how many particles per second should be emitted. Default value is 10.
virtual void SetColorRange(const ignition::math::Color &_colorStart, const ignition::math::Color &_colorEnd) override
Sets a color for all particle emitted. The actual color will be interpolated between these two colors...
Sets the material which all particles in the emitter will use.
This is used to turn on or off particle emission. Default value is false.
Set the amount by which to scale the particles in both x and y direction per second.
Initialize the visual.
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
EmitterType
Enum for emitter types.
Definition: gz/rendering/ParticleEmitter.hh:37
