gz/rendering/ogre2/Ogre2SegmentationCamera.hh
16 */
17
18 #ifndef IGNITION_RENDERING_OGRE2_OGRE2SEGMENTATIONCAMERA_HH_
19 #define IGNITION_RENDERING_OGRE2_OGRE2SEGMENTATIONCAMERA_HH_
20
21 #ifdef _WIN32
22  // Ensure that Winsock2.h is included before Windows.h, which can get
23  // pulled in by anybody (e.g., Boost).
24  #include <Winsock2.h>
25 #endif
26
27 #include <memory>
28 #include <string>
29
30 #include <ignition/common/Console.hh>
31 #include <ignition/common/Event.hh>
32
36
37 namespace ignition
38 {
39  namespace rendering
40  {
41  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
42  //
43  // Forward declaration
44  class Ogre2SegmentationCameraPrivate;
45
48  class IGNITION_RENDERING_OGRE2_VISIBLE Ogre2SegmentationCamera :
49  public BaseSegmentationCamera<Ogre2Sensor>
50  {
53
55  public: virtual ~Ogre2SegmentationCamera();
56
57  // Documentation inherited
58  public: virtual void Init() override;
59
60  // Documentation inherited
61  public: virtual void Destroy() override;
62
63  // Documentation inherited
64  public: virtual void PreRender() override;
65
66  // Documentation inherited
67  public: virtual void PostRender() override;
68
69  // Documentation inherited
70  public: virtual ignition::common::ConnectionPtr
72  std::function<void(const uint8_t *, unsigned int, unsigned int,
73  unsigned int, const std::string &)> _subscriber) override;
74
75  // Documentation inherited
76  public: virtual void Render() override;
77
80  protected: virtual RenderTargetPtr RenderTarget() const override;
81
82  // Documentation inherited
83  public: void SetBackgroundLabel(int _label) override;
84
85  // Documentation inherited
87  uint8_t * _labelBuffer) const override;
88
90  protected: void CreateCamera();
91
93  protected: virtual void CreateRenderTexture();
94
95  // Documentation inherited
96  protected: virtual void CreateSegmentationTexture() override;
97
99  protected: Ogre::Camera *ogreCamera = nullptr;
100
104
106  private: friend class Ogre2Scene;
107  };
108  }
109  }
110 }
111 #endif
Definition: gz/rendering/base/BaseSegmentationCamera.hh:38
Ogre2.x implementation of the scene class.
Definition: gz/rendering/ogre2/Ogre2Scene.hh:59
Segmentation camera used to label each pixel with a label id. Supports Semantic / Panoptic Segmentati...
Definition: gz/rendering/ogre2/Ogre2SegmentationCamera.hh:50
void LabelMapFromColoredBuffer(uint8_t *_labelBuffer) const override
Convert the colored map stored in the internal buffer to label IDs map, so users get both the colored...
Get a pointer to the render target.
Preforms any necessary final rendering work. Once rendering is complete the camera will alert any lis...
Set label for background & unlabeled items in the semantic map.
Create a texture which will hold the segmentation data.
Renders the current scene using this camera. This function assumes PreRender() has already been calle...
Create render texture.
virtual ignition::common::ConnectionPtr ConnectNewSegmentationFrame(std::function< void(const uint8_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect to the new Segmentation image event.
