gz/rendering/ogre/OgreDepthCamera.hh
16 */
17
18 #ifndef GZ_RENDERING_OGRE_OGREDEPTHCAMERA_HH_
19 #define GZ_RENDERING_OGRE_OGREDEPTHCAMERA_HH_
20
21 #ifdef _WIN32
22  // Ensure that Winsock2.h is included before Windows.h, which can get
23  // pulled in by anybody (e.g., Boost).
24  #include <Winsock2.h>
25 #endif
26
27 #include <memory>
28 #include <string>
29
39
40 #include "gz/common/Event.hh"
41 #include "gz/common/Console.hh"
42
43
44 namespace Ogre
45 {
46  class Material;
47  class RenderTarget;
48  class Texture;
49  class Viewport;
50 }
51
52 namespace ignition
53 {
54  namespace rendering
55  {
56  inline namespace IGNITION_RENDERING_VERSION_NAMESPACE {
57  //
58  // forward declaration
59  class OgreDepthCameraPrivate;
60
65  class IGNITION_RENDERING_OGRE_VISIBLE OgreDepthCamera :
66  public BaseDepthCamera<OgreSensor>
67  {
69  protected: OgreDepthCamera();
70
72  public: virtual ~OgreDepthCamera();
73
75  public: virtual void Init() override;
76
78  public: virtual void CreateDepthTexture() override;
79
82  protected: void DestroyDepthTexture();
83
85  public: virtual void PostRender() override;
86
89  public: virtual const float *DepthData() const override;
90
94  public: virtual gz::common::ConnectionPtr ConnectNewDepthFrame(
95  std::function<void(const float *, unsigned int, unsigned int,
96  unsigned int, const std::string &)> _subscriber) override;
97
101  public: virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(
102  std::function<void(const float *, unsigned int, unsigned int,
103  unsigned int, const std::string &)> _subscriber) override;
104
105  // Documentation inherited.
106  public: virtual void PreRender() override;
107
109  public: virtual void Render() override;
110
113  public: virtual void SetFarClipPlane(const double _far) override;
114
117  public: virtual void SetNearClipPlane(const double _near) override;
118
122  public: double NearClipPlane() const override;
123
127  public: double FarClipPlane() const override;
128
129  // Documentation inherited
130  public: virtual void Destroy() override;
131
136  protected: void UpdateRenderTarget(OgreRenderTexturePtr _target,
137  Ogre::Material *_material,
138  const std::string &_matName);
139
142  protected: virtual RenderTargetPtr RenderTarget() const override;
143
148  protected: static double LimitFOV(const double _fov);
149
151  protected: void CreateCamera();
152
154  private: void CreatePointCloudTexture();
155
158  protected: void DestroyPointCloudTexture();
159
161  protected: bool newData = false;
162
163  protected: bool captureData = false;
164
167
169  protected: Ogre::Viewport *depthViewport = nullptr;
170
172  protected: Ogre::Camera *ogreCamera;
173
177
178  private: friend class OgreScene;
179  private: friend class OgreRayQuery;
180  };
181  }
182  }
183 }
184 #endif
Definition: gz/rendering/base/BaseDepthCamera.hh:37
Depth camera used to render depth data into an image buffer.
Definition: gz/rendering/ogre/OgreDepthCamera.hh:67
virtual const float * DepthData() const override
All things needed to get back z buffer for depth data.
void UpdateRenderTarget(OgreRenderTexturePtr _target, Ogre::Material *_material, const std::string &_matName)
Update a render target.
Get the far clip distance.
OgreRenderTexturePtr depthTexture
Pointer to the depth texture.
Definition: gz/rendering/ogre/OgreDepthCamera.hh:166
Get a pointer to the render target.
Get the near clip distance.
Set the far clip distance.
virtual gz::common::ConnectionPtr ConnectNewDepthFrame(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect a to the new depth image signal.
Render the camera.
Ogre::Camera * ogreCamera
Pointer to the ogre camera.
Definition: gz/rendering/ogre/OgreDepthCamera.hh:172
Limit field of view taking care of using a valid value for an OGRE camera.
Destroy render texture created by CreateDepthTexture() Note: It's not virtual.
virtual gz::common::ConnectionPtr ConnectNewRgbPointCloud(std::function< void(const float *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
Connect a to the new rgb point cloud signal.
void CreateCamera()
Create the camera.
Destroy render texture created by CreatePointCloudTexture() Note: It's not virtual.
Create a texture which will hold the depth data.
Initialize the camera.
Set the near clip distance.
Implementation of the render call.
A Ray Query class used for computing ray object intersections.
Definition: gz/rendering/ogre/OgreRayQuery.hh:41
Definition: gz/rendering/ogre/OgreScene.hh:41
