#include <BaseStorage.hh>
 BaseMap ()
virtual ~BaseMap ()
virtual bool ContainsKey (const std::string &_key) const
 Determine if an elements is mapped to the given key. More...
virtual bool ContainsValue (ConstTPtr _value) const
 Determine if the given element exists in this map. More...
virtual UPtr Derived (const std::string &_key) const
virtual TPtr Get (const std::string &_key) const
 Get the element mapped to the given key. More...
 Get the element at the given index. More...
virtual bool Put (const std::string &_key, TPtr _value)
 Map to given element to the given key. If the given key is already in use, no work will be done. More...
virtual void Remove (const std::string &_key)
 Remove the element mapped to the given key. If the specified element does not exists, no work will be done. More...
virtual void Remove (TPtr _value)
 Remove the given element. If the given element does not exist no work will be done. More...
virtual void RemoveAll ()
 Remove all elements from this map. More...
 Get the number of elements in this map. More...
- Public Member Functions inherited from Map< T >
virtual ~Map ()=default
UMap map
◆ BaseMap()
◆ ~BaseMap()
~BaseMap
◆ ContainsKey()
bool ContainsKey ( const std::string &  _key) const
[in]_keyKey of the element in question
True if an elements is mapped to the given key
Implements Map< T >.
◆ ContainsValue()
bool ContainsValue ( ConstTPtr  _value) const
[in]_valueElement in question
True if the given element exists in this map
◆ Derived()
BaseMap< T, U >::UPtr Derived ( const std::string &  _key) const
◆ DerivedByIndex()
BaseMap< T, U >::UPtr DerivedByIndex ( unsigned int  _index) const
References std::advance(), std::endl(), and gzerr.
◆ Get()
BaseMap< T, U >::TPtr Get ( const std::string &  _key) const
The element mapped to the given key
◆ GetByIndex()
BaseMap< T, U >::TPtr GetByIndex ( unsigned int  _index) const
[in]_indexIndex of the element in question
The element at the given index
◆ IsValidIter()
◆ Put()
bool Put ( const std::string &  _key,
TPtr  _value
[in]_keyKey of the new element
[in]_valueElement to be mapped
True if successful
References string::empty(), std::endl(), and gzerr.
◆ Remove() [1/2]
void Remove ( const std::string &  _key)
◆ Remove() [2/2]
void Remove ( TPtr  _value)
[in]_valueKey of the element in question
◆ RemoveAll()
void RemoveAll ( )
◆ Size()
unsigned int Size ( ) const
The number of elements in this map
◆ map
UMap map
