gz::rendering Namespace Reference
Rendering classes and function useful in robot applications. More...
 GZ_RENDERING_VERSION_NAMESPACE
class  ArrowVisual
 Represents a arrow composite visual. More...
class  AxisVisual
 Represents a axis composite visual. More...
class  BaseArrowVisual
class  BaseAxisVisual
class  BaseBoundingBoxCamera
class  BaseCamera
class  BaseCapsule
 Base implementation of a Capsule Geometry. More...
class  BaseCompositeStore
class  BaseCOMVisual
 Base implementation of an center of mass visual. More...
class  BaseDepthCamera
class  BaseDirectionalLight
class  BaseDistortionPass
 Base distortion render pass. More...
class  BaseGaussianNoisePass
 Base Gaussian noise render pass. More...
class  BaseGeometry
class  BaseGeometryStore
class  BaseGizmoVisual
 A base implementation of the GizmoVisual class. More...
class  BaseGpuRays
class  BaseGrid
class  BaseHeightmap
class  BaseInertiaVisual
 Base implementation of an inertia visual. More...
class  BaseJointVisual
 Base implementation of a joint visual. More...
class  BaseLidarVisual
 Base implementation of a Lidar Visual. More...
class  BaseLight
class  BaseLightStore
class  BaseLightVisual
 Base implementation of a light visual. More...
class  BaseMap
class  BaseMarker
class  BaseMaterial
class  BaseMaterialMap
class  BaseMesh
class  BaseNode
class  BaseNodeCompositeStore
class  BaseNodeStore
class  BaseObject
class  BaseParticleEmitter
 A base implementation of the ParticleEmitter class. More...
class  BasePointLight
class  BaseProjector
 A base implementation of the Projector class. More...
class  BaseRayQuery
class  BaseRenderEngine
class  BaseRenderPass
 Base render pass that can be applied to a render target. More...
class  BaseRenderTarget
class  BaseRenderTexture
class  BaseRenderWindow
class  BaseScene
class  BaseSceneStore
class  BaseSegmentationCamera
class  BaseSensor
class  BaseSensorStore
class  BaseSpotLight
class  BaseStore
class  BaseStoreWrapper
class  BaseSubMesh
class  BaseSubMeshStore
class  BaseText
 Base implementation of a text geometry. More...
class  BaseThermalCamera
 Base implementation of the ThermalCamera class. More...
class  BaseVisual
class  BaseVisualStore
class  BaseWideAngleCamera
class  BaseWireBox
 Base implementation of a wireframe box. More...
class  BoundingBox
 2D or 3D Bounding box. It stores the position / orientation / size info of the box and its label More...
class  BoundingBoxCamera
 Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene. More...
class  Camera
 Posable camera used for rendering the scene graph. More...
class  CameraLens
 Describes a lens of a camera as amapping function of type r = c1*f*fun(theta/c2+c3) More...
class  Capsule
 Geometry for a capsule shape. The APIs allow setting the capsule's radius and length directly which ensure that the the geometry remains the shape of a capsule. In comparison, if the size is changed via the parent Node's Set*Scale function, the capsule may become deformed. More...
class  CompositeStore
class  CompositeVisual
 Represents a predefined collection of geometries and visuals. More...
class  COMVisual
 Represents a center of mass visual. More...
class  DepthCamera
class  DirectionalLight
 Represents a infinite directional light. More...
class  DistortionPass
 A render pass that applies distortion to the render target. More...
class  GaussianNoisePass
class  Geometry
class  GizmoVisual
class  GpuRays
 Generate depth ray data. More...
class  GraphicsAPIUtils
 Utils to convert GraphicsAPI to and from strings. More...
class  Grid
 Represents a grid geometry drawn along the XY plane. If vertical cell count is specified then the grid becomes 3D. More...
class  Heightmap
 A terrain defined by a heightfield. More...
class  HeightmapBlend
 Blend information to be used between textures on heightmaps. More...
class  HeightmapDescriptor
 Describes how a Heightmap should be loaded. More...
class  HeightmapTexture
 Texture to be used on heightmaps. More...
class  Image
 Encapsulates a raw image buffer and relevant properties. More...
class  InertiaVisual
 Represents a inertia visual. More...
class  JointVisual
 Represents a joint visual. More...
class  LidarVisual
 A LidarVisual geometry class. The visual appearance is based on the type specified. More...
class  Light
 Represents a light source in the scene graph. More...
class  LightVisual
 Represents a light visual. More...
class  Map
class  Marker
class  Material
 Represents a surface material of a Geometry. More...
class  Mesh
 Represents a collection of mesh geometries. More...
struct  MeshDescriptor
 Describes how a Mesh should be loaded. More...
class  MoveToHelper
 Helper class for animating a user camera to move to a target entity. More...
class  Node
class  Object
 Represents an object present in the scene graph. This includes sub-meshes, materials, render targets, as well as posable nodes. More...
class  Ogre2ArrowVisual
 Ogre2.x implementation of the arrow visual class. More...
class  Ogre2AxisVisual
 Ogre2.x implementation of the axis visual class. More...
class  Ogre2BoundingBoxCamera
 BoundingBox camera used to detect 2d / 3d bounding boxes of labeled objects in the scene. More...
class  Ogre2Camera
 Ogre2.x implementation of the camera class. More...
class  Ogre2Capsule
 Ogre 2.x implementation of a Capsule Geometry. More...
class  Ogre2COMVisual
class  Ogre2Conversions
 Conversions Conversions.hh rendering/Conversions.hh. More...
class  Ogre2DepthCamera
 Depth camera used to render depth data into an image buffer. More...
class  Ogre2DirectionalLight
 Ogre 2.x implementation of the directional light class. More...
class  Ogre2DynamicRenderable
 Dynamic renderable class that manages hardware buffers for a dynamic geometry. More...
class  Ogre2GaussianNoisePass
 Ogre2 Implementation of a Gaussian noise render pass. More...
class  Ogre2Geometry
 Ogre2.x implementation of the geometry class. More...
class  Ogre2GizmoVisual
class  Ogre2GpuRays
 Gpu Rays used to render range data into an image buffer The ogre2 implementation takes a 2 pass process to generate the final range data. 1st Pass: Creates a cubemap of range data. The cubemap is created from six cameras looking in all directions. Depending on the min/max angles specified, not all cameras need to be created. Internally in the 1st pass shaders, we reconstruct 3d viewspace pos from depth buffer data then convert them into ranges, i.e. length(pos.xyz). 2nd Pass: Samples range data from cubemap using predefined rays. The rays are generated based on the specified vertical and horizontal min/max angles and no. of samples. Each ray is a direction vector that is used to sample/lookup the range data stored in the faces of the cubemap. More...
class  Ogre2Grid
 Ogre2 implementation of a grid geometry. More...
class  Ogre2Heightmap
 Ogre implementation of a heightmap geometry. More...
class  Ogre2InertiaVisual
 Ogre2.x implementation of the inertia visual class. More...
class  Ogre2JointVisual
class  Ogre2LidarVisual
 Ogre 2.x implementation of a Lidar Visual. More...
class  Ogre2Light
 Ogre 2.x implementation of the light class. More...
class  Ogre2LightVisual
 Ogre2.x implementation of the light visual class. More...
class  Ogre2Marker
class  Ogre2Material
 Ogre 2.x implementation of the material class. More...
class  Ogre2MaterialSwitcher
 Helper class to assign unique colors to renderables. More...
class  Ogre2Mesh
 Ogre2.x implementation of the mesh class. More...
class  Ogre2MeshFactory
 Ogre2.x implementation of the mesh factory class. More...
class  Ogre2Node
 Ogre2.x implementation of the Node class. More...
class  Ogre2Object
 Ogre2.x implementation of the Object class. More...
class  Ogre2ObjectInterface
 Mixin class to provide direct access to Ogre objects. More...
class  Ogre2ParticleEmitter
class  Ogre2PointLight
 Ogre 2.x implementation of the point light class. More...
class  Ogre2Projector
 Ogre 2.x implementation of a Projector class. More...
class  Ogre2RayQuery
class  Ogre2RenderEngine
 Ogre2 render engine class. A singleton class that manages the underlying ogre2 render engine, loads its plugins, and creates resources needed for the engine to run. More...
class  Ogre2RenderEnginePlugin
 Plugin for loading ogre render engine. More...
class  Ogre2RenderPass
class  Ogre2RenderTarget
 Ogre2.x implementation of the render target class. More...
class  Ogre2RenderTargetMaterial
 Causes all objects in a scene to be rendered with the same material when rendered by a given RenderTarget. More...
class  Ogre2RenderTexture
 Ogre2.x implementation of the render texture class. More...
class  Ogre2RenderWindow
 Ogre2.x implementation of the render window class. More...
class  Ogre2Scene
 Ogre2.x implementation of the scene class. More...
class  Ogre2SceneExt
 Ogre2 implementation of the scene extension API. More...
class  Ogre2SegmentationCamera
 Segmentation camera used to label each pixel with a label id. Supports Semantic / Panoptic Segmentation. More...
class  Ogre2SelectionBuffer
 Generates a selection buffer object for a given camera. The selection buffer is used of entity selection. On setup, a unique color is assigned to each entity. Whenever a selection request is made, the selection buffer camera renders to a 1x1 sized offscreen buffer. The color value of that pixel gives the identity of the entity. More...
class  Ogre2Sensor
 Ogre2.x implementation of the sensor classs. More...
class  Ogre2SpotLight
 Ogre 2.x implementation of the spot light class. More...
class  Ogre2SubMesh
 Ogre2.x implementation of the submesh class. More...
class  Ogre2SubMeshStoreFactory
 Ogre2.x implementation of a submesh store factory class. More...
class  Ogre2ThermalCamera
 Thermal camera used to render thermal data into an image buffer. More...
class  Ogre2Visual
 Ogre2.x implementation of the visual class. More...
class  Ogre2WireBox
 Ogre2 implementation of a wire box geometry. More...
class  OgreArrowVisual
class  OgreAxisVisual
class  OgreCamera
class  OgreCapsule
 Ogre 2.x implementation of a Capsule Visual. More...
class  OgreCOMVisual
class  OgreConversions
class  OgreDepthCamera
class  OgreDirectionalLight
class  OgreDistortionPass
 Ogre implementation of the DistortionPass class. More...
class  OgreDynamicLines
 Class for drawing lines that can change. More...
class  OgreDynamicRenderable
 Abstract base class providing mechanisms for dynamically growing hardware buffers. More...
class  OgreGaussianNoisePass
 Ogre implementation of the GaussianNoisePass class. More...
class  OgreGeometry
class  OgreGizmoVisual
class  OgreGpuRays
 Gpu Rays used to render depth data into an image buffer. More...
class  OgreGrid
class  OgreHeightmap
class  OgreInertiaVisual
class  OgreJointVisual
class  OgreLidarVisual
 Ogre implementation of a Lidar Visual. More...
class  OgreLight
class  OgreLightVisual
class  OgreMarker
class  OgreMaterial
class  OgreMaterialSwitcher
class  OgreMesh
class  OgreMeshFactory
class  OgreNode
class  OgreObject
class  OgreObjectInterface
class  OgreParticleEmitter
class  OgrePointLight
class  OgreProjector
 Ogre 1.x implementation of a Projector class. More...
class  OgreRayQuery
class  OgreRenderEngine
class  OgreRenderEnginePlugin
class  OgreRenderPass
 Ogre implementation of the RenderPass class. More...
class  OgreRenderTarget
class  OgreRenderTargetMaterial
class  OgreRenderTexture
class  OgreRenderWindow
class  OgreRTShaderSystem
 Implements Ogre's Run-Time Shader system. More...
class  OgreScene
class  OgreSceneExt
 Ogre implementation of the scene extension API. More...
class  OgreSelectionBuffer
class  OgreSensor
class  OgreSpotLight
class  OgreSubMesh
class  OgreSubMeshStoreFactory
class  OgreText
 Ogre implementation of text geometry. More...
class  OgreThermalCamera
 Depth camera used to render thermal data into an image buffer. More...
class  OgreVisual
class  OgreWideAngleCamera
 Ogre implementation of WideAngleCamera. More...
class  OgreWireBox
 Ogre implementation of a wire box geometry. More...
class  OrbitViewController
 A camera view controller. More...
class  OrthoViewController
 Orthographic view controller. More...
class  ParticleEmitter
class  PixelUtil
 Provides supporting functions for PixelFormat enum. More...
class  PointLight
class  Projector
 A projector that projects a texture onto a surface. More...
class  RayQuery
class  RayQueryResult
 A class that stores ray query intersection results. More...
class  RenderEngine
 An abstract interface to a concrete render-engine. A RenderEngine is responsible for initializing a render-engine as well as creating, storing, and destroying scenes. More...
class  RenderEngineManager
 Collection of render-engines. This provides access to all the render-engines available at runtime. RenderEngine objects should not be access directly, but instead via the RenderEngineManager to maintain a flexible render-engine agnostic design. More...
class  RenderEnginePlugin
 Base plugin class for render engines. More...
class  RenderPass
class  RenderPassFactory
 A factory interface for creating render passes. More...
class  RenderPassSystem
 A class for creating and managing render passes. More...
class  RenderTarget
class  RenderTexture
 Represents a off-screen render-texture to which cameras can render images. More...
class  RenderWindow
 Represents a on-screen render-window to which cameras can render images. More...
class  Scene
 Manages a single scene-graph. This class updates scene-wide properties and holds the root scene node. A Scene also serves as a factory for all scene objects. More...
class  SceneExt
 Scene Extension class. Provides API extension to the Scene class without breaking ABI. More...
class  SegmentationCamera
 Poseable Segmentation camera used for rendering the scene graph. This camera is designed to produce segmentation data, instead of a 2D image. More...
class  Sensor
class  ShaderParam
 a variant type that holds params that can be passed to a shader More...
class  ShaderParams
 a map that holds params to be passed to a shader More...
class  ShaderUtil
 Provides supporting functions for ShaderType enum. More...
class  SpotLight
class  Store
class  StoreWrapper
class  SubMesh
 Represents a single mesh geometry. More...
class  Text
class  ThermalCamera
class  TransformController
 An transform tool for translating, rotating, and scaling objects. More...
class  ViewController
class  Visual
 Represents a visual node in a scene graph. A Visual is the only node that can have Geometry and other Visual children. More...
class  WideAngleCamera
 Wide angle camera class. More...
class  WireBox
 Draws a wireframe box. More...
typedef shared_ptr< ArrowVisual > ArrowVisualPtr
 Shared pointer to ArrowVisual. More...
typedef shared_ptr< AxisVisual > AxisVisualPtr
 Shared pointer to AxisVisual. More...
typedef shared_ptr< BaseNodeCompositeStore > BaseNodeCompositeStorePtr
typedef std::shared_ptr< BaseObject > BaseObjectPtr
typedef shared_ptr< BoundingBoxCamera > BoundingBoxCameraPtr
 Shared pointer to BoundingBoxCamera. More...
typedef shared_ptr< Camera > CameraPtr
 Shared pointer to Camera. More...
typedef shared_ptr< Capsule > CapsulePtr
 Shared pointer to Capsule. More...
typedef shared_ptr< COMVisual > COMVisualPtr
 Shared pointer to COMVisual. More...
typedef shared_ptr< const ArrowVisual > ConstArrowVisualPtr
typedef shared_ptr< const AxisVisual > ConstAxisVisualPtr
typedef shared_ptr< const BoundingBoxCamera > ConstBoundingBoxCameraPtr
typedef shared_ptr< const Camera > ConstCameraPtr
typedef shared_ptr< const DepthCamera > ConstDepthCameraPtr
typedef shared_ptr< const DirectionalLight > ConstDirectionalLightPtr
typedef shared_ptr< const GaussianNoisePass > ConstGaussianNoisePass
 Shared pointer to const GaussianNoisePass. More...
typedef shared_ptr< const Geometry > ConstGeometryPtr
typedef shared_ptr< const GizmoVisual > ConstGizmoVisualPtr
typedef shared_ptr< const GpuRays > ConstGpuRaysPtr
typedef shared_ptr< const Heightmap > ConstHeightmapPtr
typedef shared_ptr< const Image > ConstImagePtr
typedef shared_ptr< const JointVisual > ConstJointVisualPtr
typedef shared_ptr< const LidarVisual > ConstLidarVisualPtr
typedef shared_ptr< const Light > ConstLightPtr
typedef shared_ptr< const Material > ConstMaterialPtr
typedef shared_ptr< const Mesh > ConstMeshPtr
typedef shared_ptr< const Node > ConstNodePtr
typedef shared_ptr< const ObjectFactory > ConstObjectFactoryPtr
typedef shared_ptr< const Object > ConstObjectPtr
typedef shared_ptr< const ParticleEmitter > ConstParticleEmitterPtr
typedef shared_ptr< const PointLight > ConstPointLightPtr
typedef shared_ptr< const Projector > ConstProjectorPtr
typedef shared_ptr< const RayQuery > ConstRayQueryPtr
typedef shared_ptr< const RenderPass > ConstRenderPassPtr
typedef shared_ptr< const RenderPassSystem > ConstRenderPassSystemPtr
typedef shared_ptr< const RenderTarget > ConstRenderTargetPtr
typedef shared_ptr< const RenderTexture > ConstRenderTexturePtr
typedef shared_ptr< const RenderWindow > ConstRenderWindowPtr
typedef shared_ptr< const Scene > ConstScenePtr
typedef shared_ptr< const SegmentationCamera > ConstSegmentationCameraPtr
typedef shared_ptr< const Sensor > ConstSensorPtr
typedef shared_ptr< const ShaderParams > ConstShaderParamsPtr
 Shared pointer to const ShaderParams. More...
typedef shared_ptr< const SpotLight > ConstSpotLightPtr
typedef shared_ptr< const SubMesh > ConstSubMeshPtr
typedef shared_ptr< const Text > ConstTextPtr
typedef shared_ptr< const ThermalCamera > ConstThermalCameraPtr
typedef shared_ptr< const Visual > ConstVisualPtr
typedef shared_ptr< const WideAngleCamera > ConstWideAngleCameraPtr
typedef shared_ptr< DepthCamera > DepthCameraPtr
 Shared pointer to DepthCamera. More...
typedef shared_ptr< DirectionalLight > DirectionalLightPtr
 Shared pointer to DirectionalLight. More...
typedef shared_ptr< DistortionPass > DistortionPassPtr
 Shared pointer to DistortionPass. More...
typedef shared_ptr< GaussianNoisePass > GaussianNoisePassPtr
 Shared pointer to GaussianNoisePass. More...
typedef shared_ptr< Geometry > GeometryPtr
 Shared pointer to Geometry. More...
typedef Store< Geometry > GeometryStore
typedef std::shared_ptr< GeometryStore > GeometryStorePtr
typedef shared_ptr< GizmoVisual > GizmoVisualPtr
 Shared pointer to GizmoVisual. More...
typedef shared_ptr< GpuRays > GpuRaysPtr
 Shared pointer to GpuRays. More...
typedef shared_ptr< Grid > GridPtr
 Shared pointer to Grid. More...
typedef shared_ptr< Heightmap > HeightmapPtr
 Shared pointer to Heightmap. More...
using IgnOgreRenderingMode = GzOgreRenderingMode
typedef shared_ptr< Image > ImagePtr
 Shared pointer to Image. More...
typedef shared_ptr< InertiaVisual > InertiaVisualPtr
typedef shared_ptr< JointVisual > JointVisualPtr
 Shared pointer to JointVisual. More...
typedef shared_ptr< LidarVisual > LidarVisualPtr
 Shared pointer to LidarVisual. More...
typedef shared_ptr< Light > LightPtr
 Shared pointer to Light. More...
typedef Store< Light > LightStore
typedef std::shared_ptr< LightStore > LightStorePtr
typedef shared_ptr< LightVisual > LightVisualPtr
typedef shared_ptr< Marker > MarkerPtr
 Shared pointer to Marker. More...
typedef Map< Material > MaterialMap
typedef std::shared_ptr< MaterialMap > MaterialMapPtr
typedef shared_ptr< Material > MaterialPtr
 Shared pointer to Material. More...
typedef shared_ptr< Mesh > MeshPtr
 Shared pointer to Mesh. More...
typedef CompositeStore< Node > NodeCompositeStore
typedef std::shared_ptr< NodeCompositeStore > NodeCompositeStorePtr
typedef shared_ptr< Node > NodePtr
 Shared pointer to Node. More...
typedef Store< Node > NodeStore
typedef std::shared_ptr< NodeStore > NodeStorePtr
typedef shared_ptr< ObjectFactory > ObjectFactoryPtr
 Shared pointer to ObjectFactory. More...
typedef shared_ptr< Object > ObjectPtr
 Shared pointer to Object. More...
typedef shared_ptr< Ogre2ArrowVisual > Ogre2ArrowVisualPtr
typedef shared_ptr< Ogre2AxisVisual > Ogre2AxisVisualPtr
typedef shared_ptr< Ogre2BoundingBoxCamera > Ogre2BoundingBoxCameraPtr
typedef shared_ptr< Ogre2Camera > Ogre2CameraPtr
typedef shared_ptr< Ogre2Capsule > Ogre2CapsulePtr
typedef shared_ptr< Ogre2COMVisual > Ogre2COMVisualPtr
typedef shared_ptr< Ogre2DepthCamera > Ogre2DepthCameraPtr
typedef shared_ptr< Ogre2DirectionalLight > Ogre2DirectionalLightPtr
typedef shared_ptr< Ogre2Geometry > Ogre2GeometryPtr
typedef BaseGeometryStore< Ogre2Geometry > Ogre2GeometryStore
typedef shared_ptr< Ogre2GeometryStore > Ogre2GeometryStorePtr
typedef shared_ptr< Ogre2GizmoVisual > Ogre2GizmoVisualPtr
typedef shared_ptr< Ogre2GpuRays > Ogre2GpuRaysPtr
typedef shared_ptr< Ogre2Grid > Ogre2GridPtr
typedef shared_ptr< Ogre2Heightmap > Ogre2HeightmapPtr
typedef shared_ptr< Ogre2InertiaVisual > Ogre2InertiaVisualPtr
typedef shared_ptr< Ogre2JointVisual > Ogre2JointVisualPtr
typedef shared_ptr< Ogre2LidarVisual > Ogre2LidarVisualPtr
typedef shared_ptr< Ogre2Light > Ogre2LightPtr
typedef BaseLightStore< Ogre2Light > Ogre2LightStore
typedef shared_ptr< Ogre2LightStore > Ogre2LightStorePtr
typedef shared_ptr< Ogre2LightVisual > Ogre2LightVisualPtr
typedef shared_ptr< Ogre2Marker > Ogre2MarkerPtr
typedef BaseMaterialMap< Ogre2Material > Ogre2MaterialMap
typedef shared_ptr< Ogre2MaterialMap > Ogre2MaterialMapPtr
typedef shared_ptr< Ogre2Material > Ogre2MaterialPtr
typedef shared_ptr< Ogre2MeshFactory > Ogre2MeshFactoryPtr
typedef shared_ptr< Ogre2Mesh > Ogre2MeshPtr
typedef shared_ptr< Ogre2Node > Ogre2NodePtr
typedef BaseNodeStore< Ogre2Node > Ogre2NodeStore
typedef shared_ptr< Ogre2NodeStore > Ogre2NodeStorePtr
typedef shared_ptr< Ogre2ObjectInterface > Ogre2ObjectInterfacePtr
typedef shared_ptr< Ogre2Object > Ogre2ObjectPtr
typedef shared_ptr< Ogre2ParticleEmitter > Ogre2ParticleEmitterPtr
typedef shared_ptr< Ogre2PointLight > Ogre2PointLightPtr
typedef shared_ptr< Ogre2Projector > Ogre2ProjectorPtr
typedef shared_ptr< Ogre2RayQuery > Ogre2RayQueryPtr
typedef shared_ptr< Ogre2RenderEngine > Ogre2RenderEnginePtr
typedef shared_ptr< Ogre2RenderTargetMaterial > Ogre2RenderTargetMaterialPtr
typedef shared_ptr< Ogre2RenderTarget > Ogre2RenderTargetPtr
typedef shared_ptr< Ogre2RenderTexture > Ogre2RenderTexturePtr
typedef shared_ptr< Ogre2RenderWindow > Ogre2RenderWindowPtr
typedef shared_ptr< Ogre2Scene > Ogre2ScenePtr
typedef BaseSceneStore< Ogre2Scene > Ogre2SceneStore
typedef shared_ptr< Ogre2SceneStore > Ogre2SceneStorePtr
typedef shared_ptr< Ogre2SegmentationCamera > Ogre2SegmentationCameraPtr
typedef shared_ptr< Ogre2Sensor > Ogre2SensorPtr
typedef BaseSensorStore< Ogre2Sensor > Ogre2SensorStore
typedef shared_ptr< Ogre2SensorStore > Ogre2SensorStorePtr
typedef shared_ptr< Ogre2SpotLight > Ogre2SpotLightPtr
typedef shared_ptr< Ogre2SubMesh > Ogre2SubMeshPtr
typedef BaseSubMeshStore< Ogre2SubMesh > Ogre2SubMeshStore
typedef shared_ptr< Ogre2SubMeshStore > Ogre2SubMeshStorePtr
typedef shared_ptr< Ogre2ThermalCamera > Ogre2ThermalCameraPtr
typedef shared_ptr< Ogre2Visual > Ogre2VisualPtr
typedef BaseVisualStore< Ogre2Visual > Ogre2VisualStore
typedef shared_ptr< Ogre2VisualStore > Ogre2VisualStorePtr
typedef shared_ptr< Ogre2WireBox > Ogre2WireBoxPtr
typedef shared_ptr< OgreArrowVisual > OgreArrowVisualPtr
typedef shared_ptr< OgreAxisVisual > OgreAxisVisualPtr
typedef shared_ptr< OgreCamera > OgreCameraPtr
typedef shared_ptr< OgreCapsule > OgreCapsulePtr
typedef shared_ptr< OgreCOMVisual > OgreCOMVisualPtr
typedef shared_ptr< OgreDepthCamera > OgreDepthCameraPtr
typedef shared_ptr< OgreDirectionalLight > OgreDirectionalLightPtr
typedef shared_ptr< OgreGeometry > OgreGeometryPtr
typedef BaseGeometryStore< OgreGeometry > OgreGeometryStore
typedef shared_ptr< OgreGeometryStore > OgreGeometryStorePtr
typedef shared_ptr< OgreGizmoVisual > OgreGizmoVisualPtr
typedef shared_ptr< OgreGpuRays > OgreGpuRaysPtr
typedef shared_ptr< OgreGrid > OgreGridPtr
typedef shared_ptr< OgreHeightmap > OgreHeightmapPtr
typedef shared_ptr< OgreInertiaVisual > OgreInertiaVisualPtr
typedef shared_ptr< OgreJointVisual > OgreJointVisualPtr
typedef shared_ptr< OgreLidarVisual > OgreLidarVisualPtr
typedef shared_ptr< OgreLight > OgreLightPtr
typedef BaseLightStore< OgreLight > OgreLightStore
typedef shared_ptr< OgreLightStore > OgreLightStorePtr
typedef shared_ptr< OgreLightVisual > OgreLightVisualPtr
typedef shared_ptr< OgreMarker > OgreMarkerPtr
typedef BaseMaterialMap< OgreMaterial > OgreMaterialMap
typedef shared_ptr< OgreMaterialMap > OgreMaterialMapPtr
typedef shared_ptr< OgreMaterial > OgreMaterialPtr
typedef shared_ptr< OgreMeshFactory > OgreMeshFactoryPtr
typedef shared_ptr< OgreMesh > OgreMeshPtr
typedef shared_ptr< OgreNode > OgreNodePtr
typedef BaseNodeStore< OgreNode > OgreNodeStore
typedef shared_ptr< OgreNodeStore > OgreNodeStorePtr
typedef shared_ptr< OgreObjectInterface > OgreObjectInterfacePtr
typedef shared_ptr< OgreObject > OgreObjectPtr
typedef shared_ptr< OgreParticleEmitter > OgreParticleEmitterPtr
typedef shared_ptr< OgrePointLight > OgrePointLightPtr
typedef shared_ptr< OgreProjector > OgreProjectorPtr
typedef shared_ptr< OgreRayQuery > OgreRayQueryPtr
typedef shared_ptr< OgreRenderEngine > OgreRenderEnginePtr
typedef shared_ptr< OgreRenderTargetMaterial > OgreRenderTargetMaterialPtr
typedef shared_ptr< OgreRenderTarget > OgreRenderTargetPtr
typedef shared_ptr< OgreRenderTexture > OgreRenderTexturePtr
typedef shared_ptr< OgreRenderWindow > OgreRenderWindowPtr
typedef shared_ptr< OgreScene > OgreScenePtr
typedef BaseSceneStore< OgreScene > OgreSceneStore
typedef shared_ptr< OgreSceneStore > OgreSceneStorePtr
typedef shared_ptr< OgreSensor > OgreSensorPtr
typedef BaseSensorStore< OgreSensor > OgreSensorStore
typedef shared_ptr< OgreSensorStore > OgreSensorStorePtr
typedef shared_ptr< OgreSpotLight > OgreSpotLightPtr
typedef shared_ptr< OgreSubMesh > OgreSubMeshPtr
typedef BaseSubMeshStore< OgreSubMesh > OgreSubMeshStore
typedef shared_ptr< OgreSubMeshStore > OgreSubMeshStorePtr
typedef shared_ptr< OgreText > OgreTextPtr
typedef shared_ptr< OgreThermalCamera > OgreThermalCameraPtr
typedef shared_ptr< OgreVisual > OgreVisualPtr
typedef BaseVisualStore< OgreVisual > OgreVisualStore
typedef shared_ptr< OgreVisualStore > OgreVisualStorePtr
typedef shared_ptr< OgreWideAngleCamera > OgreWideAngleCameraPtr
typedef shared_ptr< OgreWireBox > OgreWireBoxPtr
typedef shared_ptr< ParticleEmitter > ParticleEmitterPtr
 Shared pointer to ParticleEmitter. More...
typedef shared_ptr< PointLight > PointLightPtr
 Shared pointer to PointLight. More...
typedef shared_ptr< Projector > ProjectorPtr
 Shared pointer to Projector. More...
typedef shared_ptr< RayQuery > RayQueryPtr
 Shared pointer to RayQuery. More...
typedef shared_ptr< RenderPass > RenderPassPtr
 Shared pointer to RenderPass. More...
typedef shared_ptr< RenderPassSystem > RenderPassSystemPtr
 Shared pointer to RenderPassSystem. More...
typedef shared_ptr< RenderTarget > RenderTargetPtr
 Shared pointer to RenderTarget. More...
typedef shared_ptr< RenderTexture > RenderTexturePtr
 Shared pointer to RenderTexture. More...
typedef shared_ptr< RenderWindow > RenderWindowPtr
 Shared pointer to RenderWindow. More...
typedef shared_ptr< Scene > ScenePtr
 Shared pointer to Scene. More...
typedef Store< Scene > SceneStore
typedef std::shared_ptr< SceneStore > SceneStorePtr
typedef shared_ptr< SegmentationCamera > SegmentationCameraPtr
 Shared pointer to Segmentation Camera. More...
typedef shared_ptr< Sensor > SensorPtr
 Shared pointer to Sensor. More...
typedef Store< Sensor > SensorStore
typedef std::shared_ptr< SensorStore > SensorStorePtr
typedef shared_ptr< ShaderParams > ShaderParamsPtr
 Shared pointer to ShaderParams. More...
template<class T >
using shared_ptr = std::shared_ptr< T >
typedef shared_ptr< SpotLight > SpotLightPtr
 Shared pointer to SpotLight. More...
typedef shared_ptr< SubMesh > SubMeshPtr
 Shared pointer to SubMesh. More...
typedef Store< SubMesh > SubMeshStore
typedef std::shared_ptr< SubMeshStore > SubMeshStorePtr
typedef shared_ptr< Text > TextPtr
 Shared pointer to Text. More...
typedef shared_ptr< ThermalCamera > ThermalCameraPtr
 Shared pointer to ThermalCamera. More...
using Variant = std::variant< std::monostate, int, float, double, std::string, bool, unsigned int, int64_t, uint64_t >
 Alias for a variant that can hold various types of data. The first type of the variant is std::monostate in order to prevent default-constructed variants from holding a type (a default-constructed variant is returned when a user calls Node::UserData with a key that doesn't exist for the node. In this case, since the key doesn't exist, the variant that is returned shouldn't hold any types - an "empty variant" should be returned for keys that don't exist) More...
typedef shared_ptr< Visual > VisualPtr
 Shared pointer to Visual. More...
typedef Store< Visual > VisualStore
typedef std::shared_ptr< VisualStore > VisualStorePtr
typedef shared_ptr< WideAngleCamera > WideAngleCameraPtr
 Shared pointer to Wide Angle Camera. More...
typedef shared_ptr< WireBox > WireBoxPtr
 Shared pointer to WireBox. More...
Enumerations
enum  AngleFunctionType { AFT_IDENTITY = 0, AFT_SIN = 1, AFT_TAN = 2 }
 Enum for angle function types. More...
enum  BoundingBoxType { BBT_FULLBOX2D = 0, BBT_VISIBLEBOX2D = 1, BBT_BOX3D = 2 }
 BoundingBox types for Visible / Full 2D Boxes / 3D Boxes. More...
enum  CameraProjectionType { CPT_PERSPECTIVE, CPT_ORTHOGRAPHIC }
 Enum for projection types. More...
enum  EmitterType {
  EM_POINT = 0, EM_BOX = 1, EM_CYLINDER = 2, EM_ELLIPSOID = 3,
  EM_NUM_EMITTERS = 4
 Enum for emitter types. More...
enum  GraphicsAPI : uint16_t {
  GRAPHICS_API_BEGIN = 0, UNKNOWN = GRAPHICS_API_BEGIN, OPENGL = 1, DIRECT3D11 = 2,
  VULKAN = 3, METAL = 4, GRAPHICS_API_END
 The graphics API used by the render engine. More...
enum  GzOgreRenderingMode {
  GORM_NORMAL = 0, IORM_NORMAL = 0, GORM_SOLID_COLOR = 1, IORM_SOLID_COLOR = 1,
  GORM_SOLID_THERMAL_COLOR_TEXTURED = 2, IORM_SOLID_THERMAL_COLOR_TEXTURED = 2, GORM_COUNT = 3, IORM_COUNT = 3
 Rendering modes so that GzHlms implementations follow alternate code paths or extra customizations when they're enabled. More...
enum  JointVisualType {
  JVT_NONE = 0, JVT_REVOLUTE = 1, JVT_REVOLUTE2 = 2, JVT_PRISMATIC = 3,
  JVT_UNIVERSAL = 4, JVT_BALL = 5, JVT_SCREW = 6, JVT_GEARBOX = 7,
  JVT_FIXED = 8
 Enum for JointVisual types. More...
enum  LidarVisualType { LVT_NONE = 0, LVT_RAY_LINES = 1, LVT_POINTS = 2, LVT_TRIANGLE_STRIPS = 3 }
 Enum for LidarVisual types. More...
enum  LightVisualType { LVT_EMPTY = 0, LVT_POINT = 1, LVT_DIRECTIONAL = 2, LVT_SPOT = 3 }
 Enum for LightVisual types. More...
enum  MappingFunctionType {
  MFT_GNOMONIC = 0, MFT_STEREOGRAPHIC = 1, MFT_EQUIDISTANT = 2, MFT_EQUISOLID_ANGLE = 3,
  MFT_ORTHOGRAPHIC = 4, MFT_CUSTOM = 5
 Enum for mapping function types. More...
enum  MarkerType {
  MT_NONE = 0, MT_BOX = 1, MT_CYLINDER = 2, MT_LINE_STRIP = 3,
  MT_LINE_LIST = 4, MT_POINTS = 5, MT_SPHERE = 6, MT_TEXT = 7,
  MT_TRIANGLE_FAN = 8, MT_TRIANGLE_LIST = 9, MT_TRIANGLE_STRIP = 10, MT_CAPSULE = 11
 Enum for marker types. More...
enum  MaterialType { MT_CLASSIC = 0, MT_PBS = 1 }
 An enum for the type of material. More...
enum  PixelFormat {
  PF_UNKNOWN = 0, PF_L8 = 1, PF_R8G8B8 = 2, PF_B8G8R8 = 3,
  PF_BAYER_RGGB8 = 4, PF_BAYER_BGGR8 = 5, PF_BAYER_GBRG8 = 6, PF_BAYER_GRBG8 = 7,
  PF_FLOAT32_R = 8, PF_FLOAT32_RGBA = 9, PF_FLOAT32_RGB = 10, PF_L16 = 11,
  PF_R8G8B8A8 = 12, PF_COUNT = 13
 Image pixel format types. More...
enum  SegmentationType { ST_SEMANTIC = 0, ST_PANOPTIC = 1 }
 Segmentation types for Semantic / Panpoptic segmentation. More...
enum  ShaderType {
  ST_UNKNOWN = 0, ST_PIXEL = 1, ST_VERTEX = 2, ST_NORM_OBJ = 3,
  ST_NORM_TAN = 4, ST_COUNT = 5
 Available types of shaders. Note that not all rendering-engines will be able to use each type. They will instead default to the closest alternative. More...
enum  TextHorizontalAlign { LEFT = 0, CENTER = 1, RIGHT = 2 }
 Text Horizontal alignment. More...
enum  TextVerticalAlign { BOTTOM = 0, CENTER = 1, TOP = 2 }
 Text vertical alignment. More...
enum  TransformAxis {
  TA_NONE = 0, TA_TRANSLATION_X = 0x00000001, TA_TRANSLATION_Y = 0x00000002, TA_TRANSLATION_Z = 0x00000004,
  TA_ROTATION_X = 0x00000010, TA_ROTATION_Y = 0x00000020, TA_ROTATION_Z = 0x00000040, TA_SCALE_X = 0x00000100,
  TA_SCALE_Y = 0x00000200, TA_SCALE_Z = 0x00000400
 Unique identifiers for transformation axes. More...
enum  TransformMode {
  TM_NONE = 0, TM_TRANSLATION = TA_TRANSLATION_X | TA_TRANSLATION_Y | TA_TRANSLATION_Z, TM_ROTATION = TA_ROTATION_X | TA_ROTATION_Y | TA_ROTATION_Z, TM_SCALE = TA_SCALE_X | TA_SCALE_Y,
  TA_SCALEZ
 Unique identifiers for transformation modes. More...
enum  TransformSpace { TS_LOCAL, TS_WORLD }
 Unique identifiers for transformation spaces. More...
Functions
Image convertRGBToBayer (const Image &_image, PixelFormat _bayerFormat)
 convert an RGB image data into bayer image data More...
GraphicsAPI defaultGraphicsAPI ()
 Convenience function to get the default graphics API based on current platform. More...
RenderEngine * engine (const std::string &_name, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
 Get the render-engine registered under the given name. If no render-engine is registered under the given name, NULL will be returned. If the engine is registered, but not loaded, this function will load it. More...
RenderEngine * engine (const unsigned int _index, const std::map< std::string, std::string > &_params={}, const std::string &_path="")
 Get the render-engine registered at the given index. If no render-engine is registered at the given index, NULL will be returned. If the engine is registered, but not loaded, this function will load it. More...
unsigned int engineCount ()
 Get the number of available render-engines. More...
bool fini ()
 Destroy all render-engines and related resources. More...
std::string getEngineInstallDir ()
 getEngineInstallDir return the install directory of the engines More...
std::string getInstallPrefix ()
 getInstallPrefix return the install prefix of the library i.e. CMAKE_INSTALL_PREFIX unless the library has been moved More...
std::string getResourcePath ()
 getResourcePath return the resource path More...
bool hasEngine (const std::string &_name)
 Determine if a render-engine is registered under the given name. More...
bool init ()
 Initialized shared render-engine features. More...
bool isEngineLoaded (const std::string &_name)
 Determine if a render-engine is already loaded. More...
bool load ()
 Load shared render-engine resources. More...
std::vector< std::string > loadedEngines ()
 Get the names of all engines currently loaded. More...
gz::math::Matrix3d projectionToCameraIntrinsic (const gz::math::Matrix4d &_projectionMatrix, double _width, double _height)
 Convert a given camera projection matrix to an intrinsics matrix. Intrinsics matrix is different from the matrix returned by Camera::ProjectionMatrix(), which is used by OpenGL internally. The matrix returned contains the camera calibrated values. More...
void registerEngine (const std::string &_name, RenderEngine *_engine)
 Register a new render-engine under the given name. If the given name is already in use, the render-engine will not be registered. More...
ScenePtr sceneFromFirstRenderEngine ()
 Most applications will only have one rendering engine loaded at a time, and only one scene within that. This helper function gets the first scene that can be found in the first loaded rendering engine. More...
float screenScalingFactor ()
 Get the screen scaling factor. More...
math::Vector3d screenToPlane (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, const float _offset=0.0)
 Retrieve the point on a plane at z = 0 in the 3D scene hit by a ray cast from the given 2D screen coordinates. More...
math::Vector3d screenToScene (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, float _maxDistance=10.0)
 Retrieve the first point on a surface in the 3D scene hit by a ray cast from the given 2D screen coordinates. More...
math::Vector3d screenToScene (const math::Vector2i &_screenPos, const CameraPtr &_camera, const RayQueryPtr &_rayQuery, RayQueryResult &_rayResult, float _maxDistance=10.0)
void setPluginPaths (const std::list< std::string > &_paths)
 Set the plugin paths from which render engines can be loaded. More...
gz::math::AxisAlignedBox transformAxisAlignedBox (const gz::math::AxisAlignedBox &_box, const gz::math::Pose3d &_pose)
 Transform a bounding box. More...
bool unloadEngine (const std::string &_name)
 Unload the render-engine registered under the given name. More...
void unregisterEngine (const std::string &_name)
 Unregister a render-engine registered under the given name. If the no render-engine is registered under the given name no work will be done. More...
void unregisterEngine (const unsigned int _index)
 Unregister a render-engine at the given index. If the no render-engine is registered at the given index, no work will be done. More...
void unregisterEngine (RenderEngine *_engine)
 Unregister the given render-engine. If the given render-engine is not currently registered, no work will be done. More...
Variables
const std::string depth_fragment_shader_file
const std::string depth_vertex_shader_file
static const common::Pbr kDefaultPbr
 Default pbr material properties. More...
Typedef Documentation
◆ ArrowVisualPtr
Shared pointer to const ArrowVisual.
◆ AxisVisualPtr
Shared pointer to const AxisVisual.
◆ BaseNodeCompositeStorePtr
◆ BaseObjectPtr
◆ BoundingBoxCameraPtr
Shared pointer to const BoundingBox Camera.
◆ CameraPtr
const CameraPtr
Shared pointer to const Camera.
◆ CapsulePtr
◆ COMVisualPtr
◆ ConstArrowVisualPtr
◆ ConstAxisVisualPtr
◆ ConstBoundingBoxCameraPtr
◆ ConstCameraPtr
◆ ConstDepthCameraPtr
◆ ConstDirectionalLightPtr
◆ ConstGaussianNoisePass
◆ ConstGeometryPtr
◆ ConstGizmoVisualPtr
◆ ConstGpuRaysPtr
◆ ConstHeightmapPtr
◆ ConstImagePtr
typedef shared_ptr<const Image> ConstImagePtr
◆ ConstJointVisualPtr
◆ ConstLidarVisualPtr
◆ ConstLightPtr
typedef shared_ptr<const Light> ConstLightPtr
◆ ConstMaterialPtr
◆ ConstMeshPtr
typedef shared_ptr<const Mesh> ConstMeshPtr
◆ ConstNodePtr
typedef shared_ptr<const Node> ConstNodePtr
◆ ConstObjectFactoryPtr
typedef shared_ptr<const ObjectFactory> ConstObjectFactoryPtr
◆ ConstObjectPtr
◆ ConstParticleEmitterPtr
◆ ConstPointLightPtr
◆ ConstProjectorPtr
◆ ConstRayQueryPtr
◆ ConstRenderPassPtr
◆ ConstRenderPassSystemPtr
◆ ConstRenderTargetPtr
◆ ConstRenderTexturePtr
◆ ConstRenderWindowPtr
◆ ConstScenePtr
typedef shared_ptr<const Scene> ConstScenePtr
◆ ConstSegmentationCameraPtr
◆ ConstSensorPtr
◆ ConstShaderParamsPtr
◆ ConstSpotLightPtr
◆ ConstSubMeshPtr
◆ ConstTextPtr
typedef shared_ptr<const Text> ConstTextPtr
◆ ConstThermalCameraPtr
◆ ConstVisualPtr
◆ ConstWideAngleCameraPtr
◆ DepthCameraPtr
Shared pointer to const DepthCamera.
◆ DirectionalLightPtr
Shared pointer to const DirectionalLight.
◆ DistortionPassPtr
◆ GaussianNoisePassPtr
◆ GeometryPtr
const GeometryPtr
Shared pointer to const Geometry.
◆ GeometryStore
◆ GeometryStorePtr
◆ GizmoVisualPtr
Shared pointer to const GizmoVisual.
◆ GpuRaysPtr
const GpuRaysPtr
Shared pointer to const GpuRays.
◆ GridPtr
◆ HeightmapPtr
const HeightmapPtr
Shared pointer to const Heightmap.
◆ ImagePtr
const ImagePtr
Shared pointer to const Image.
◆ InertiaVisualPtr
◆ JointVisualPtr
Shared pointer to const JointVisual.
◆ LidarVisualPtr
Shared pointer to const LidarVisual.
◆ LightPtr
const LightPtr
Shared pointer to const Light.
◆ LightStore
◆ LightStorePtr
◆ LightVisualPtr
◆ MarkerPtr
◆ MaterialMap
◆ MaterialMapPtr
◆ MaterialPtr
const MaterialPtr
Shared pointer to const Material.
◆ MeshPtr
const MeshPtr
Shared pointer to const Mesh.
◆ NodeCompositeStore
◆ NodeCompositeStorePtr
◆ NodePtr
const NodePtr
Shared pointer to const Node.
◆ NodeStore
typedef Store<Node> NodeStore
◆ NodeStorePtr
◆ ObjectFactoryPtr
Shared pointer to const ObjectFactory.
◆ ObjectPtr
const ObjectPtr
Shared pointer to const Object.
◆ Ogre2ArrowVisualPtr
◆ Ogre2AxisVisualPtr
◆ Ogre2BoundingBoxCameraPtr
◆ Ogre2CameraPtr
◆ Ogre2CapsulePtr
◆ Ogre2COMVisualPtr
◆ Ogre2DepthCameraPtr
◆ Ogre2DirectionalLightPtr
◆ Ogre2GeometryPtr
◆ Ogre2GeometryStore
◆ Ogre2GeometryStorePtr
◆ Ogre2GizmoVisualPtr
◆ Ogre2GpuRaysPtr
◆ Ogre2GridPtr
◆ Ogre2HeightmapPtr
◆ Ogre2InertiaVisualPtr
◆ Ogre2JointVisualPtr
◆ Ogre2LidarVisualPtr
◆ Ogre2LightPtr
◆ Ogre2LightStore
◆ Ogre2LightStorePtr
◆ Ogre2LightVisualPtr
◆ Ogre2MarkerPtr
◆ Ogre2MaterialMap
◆ Ogre2MaterialMapPtr
◆ Ogre2MaterialPtr
◆ Ogre2MeshFactoryPtr
◆ Ogre2MeshPtr
◆ Ogre2NodePtr
◆ Ogre2NodeStore
◆ Ogre2NodeStorePtr
◆ Ogre2ObjectInterfacePtr
◆ Ogre2ObjectPtr
◆ Ogre2ParticleEmitterPtr
◆ Ogre2PointLightPtr
◆ Ogre2ProjectorPtr
◆ Ogre2RayQueryPtr
◆ Ogre2RenderEnginePtr
◆ Ogre2RenderTargetMaterialPtr
◆ Ogre2RenderTargetPtr
◆ Ogre2RenderTexturePtr
◆ Ogre2RenderWindowPtr
◆ Ogre2ScenePtr
◆ Ogre2SceneStore
◆ Ogre2SceneStorePtr
◆ Ogre2SegmentationCameraPtr
◆ Ogre2SensorPtr
◆ Ogre2SensorStore
◆ Ogre2SensorStorePtr
◆ Ogre2SpotLightPtr
◆ Ogre2SubMeshPtr
◆ Ogre2SubMeshStore
◆ Ogre2SubMeshStorePtr
◆ Ogre2ThermalCameraPtr
◆ Ogre2VisualPtr
◆ Ogre2VisualStore
◆ Ogre2VisualStorePtr
◆ Ogre2WireBoxPtr
◆ OgreArrowVisualPtr
◆ OgreAxisVisualPtr
◆ OgreCameraPtr
◆ OgreCapsulePtr
◆ OgreCOMVisualPtr
◆ OgreDepthCameraPtr
◆ OgreDirectionalLightPtr
◆ OgreGeometryPtr
◆ OgreGeometryStore
◆ OgreGeometryStorePtr
◆ OgreGizmoVisualPtr
◆ OgreGpuRaysPtr
◆ OgreGridPtr
◆ OgreHeightmapPtr
◆ OgreInertiaVisualPtr
◆ OgreJointVisualPtr
◆ OgreLidarVisualPtr
◆ OgreLightPtr
◆ OgreLightStore
◆ OgreLightStorePtr
◆ OgreLightVisualPtr
◆ OgreMarkerPtr
◆ OgreMaterialMap
◆ OgreMaterialMapPtr
◆ OgreMaterialPtr
◆ OgreMeshFactoryPtr
◆ OgreMeshPtr
◆ OgreNodePtr
◆ OgreNodeStore
◆ OgreNodeStorePtr
◆ OgreObjectInterfacePtr
◆ OgreObjectPtr
◆ OgreParticleEmitterPtr
◆ OgrePointLightPtr
◆ OgreProjectorPtr
◆ OgreRayQueryPtr
◆ OgreRenderEnginePtr
◆ OgreRenderTargetMaterialPtr
◆ OgreRenderTargetPtr
◆ OgreRenderTexturePtr
◆ OgreRenderWindowPtr
◆ OgreScenePtr
◆ OgreSceneStore
◆ OgreSceneStorePtr
◆ OgreSensorPtr
◆ OgreSensorStore
◆ OgreSensorStorePtr
◆ OgreSpotLightPtr
◆ OgreSubMeshPtr
◆ OgreSubMeshStore
◆ OgreSubMeshStorePtr
◆ OgreTextPtr
◆ OgreThermalCameraPtr
◆ OgreVisualPtr
◆ OgreVisualStore
◆ OgreVisualStorePtr
◆ OgreWideAngleCameraPtr
◆ OgreWireBoxPtr
◆ ParticleEmitterPtr
Shared pointer to const ParticleEmitter.
◆ PointLightPtr
Shared pointer to const PointLight.
◆ ProjectorPtr
const ProjectorPtr
Shared pointer to const Projector.
◆ RayQueryPtr
const RayQueryPtr
◆ RenderPassPtr
Shared pointer to const RenderPass.
◆ RenderPassSystemPtr
Shared pointer to const RenderPassSystem.
◆ RenderTargetPtr
Shared pointer to const RenderTarget.
◆ RenderTexturePtr
Shared pointer to const RenderTexture.
◆ RenderWindowPtr
Shared pointer to const RenderWindow.
◆ ScenePtr
const ScenePtr
Shared pointer to const Scene.
◆ SceneStore
◆ SceneStorePtr
◆ SegmentationCameraPtr
Shared pointer to const Wide Angle Camera.
Shared pointer to const Segmentation Camera.
◆ SensorPtr
const SensorPtr
Shared pointer to const Sensor.
◆ SensorStore
◆ SensorStorePtr
◆ ShaderParamsPtr
◆ shared_ptr
◆ SpotLightPtr
const SpotLightPtr
Shared pointer to const SpotLight.
◆ SubMeshPtr
const SubMeshPtr
Shared pointer to const SubMesh.
◆ SubMeshStore
◆ SubMeshStorePtr
◆ TextPtr
◆ ThermalCameraPtr
Shared pointer to const ThermalCamera.
◆ Variant
using Variant = std::variant<std::monostate, int, float, double, std::string, bool, unsigned int, int64_t, uint64_t>
◆ VisualPtr
const VisualPtr
Shared pointer to const Visual.
◆ VisualStore
◆ VisualStorePtr
◆ WideAngleCameraPtr
◆ WireBoxPtr
◆ AngleFunctionType
Enumerator
AFT_IDENTITY
identity
AFT_SIN
sin
AFT_TAN
TAN.
◆ BoundingBoxType
strong
Enumerator
BBT_FULLBOX2D
2D box that shows the full box of occluded objects
BBT_VISIBLEBOX2D
2D box that shows the visible part of the occluded object
BBT_BOX3D
3D oriented box
◆ CameraProjectionType
Enumerator
CPT_PERSPECTIVE
Perspective projection.
CPT_ORTHOGRAPHIC
Orthographic projection.
◆ EmitterType
Enumerator
EM_POINT
Point emitter.
EM_BOX
Box emitter.
EM_CYLINDER
Cylinder emitter.
EM_ELLIPSOID
Ellipsoid emitter.
EM_NUM_EMITTERS
Total number of emitters (keep always at the end).
◆ GraphicsAPI
strong
Enumerator
GRAPHICS_API_BEGIN
UNKNOWN
Unknown graphics interface.
OPENGL
OpenGL graphics interface.
DIRECT3D11
Direct3D11 graphics interface.
VULKAN
Vulkan graphics interface.
METAL
Metal graphics interface.
GRAPHICS_API_END
◆ JointVisualType
Enumerator
JVT_NONE
No type.
JVT_REVOLUTE
Revolute joint type.
JVT_REVOLUTE2
Revolute2 joint type.
JVT_PRISMATIC
Prismatic joint type.
JVT_UNIVERSAL
Universal joint type.
JVT_BALL
Ball joint type.
JVT_SCREW
Screw joint type.
JVT_GEARBOX
Gearbox joint type.
JVT_FIXED
Fixed joint type.
◆ LidarVisualType
Enumerator
LVT_NONE
No type.
LVT_RAY_LINES
Ray line visual.
LVT_POINTS
Points visual.
LVT_TRIANGLE_STRIPS
Triangle strips visual.
◆ LightVisualType
Enumerator
LVT_EMPTY
No type.
LVT_POINT
Point light.
LVT_DIRECTIONAL
Directional light.
LVT_SPOT
Spot light.
◆ MappingFunctionType
Enumerator
MFT_GNOMONIC
Gnomonic.
MFT_STEREOGRAPHIC
Stereographic.
MFT_EQUIDISTANT
Equidistant.
MFT_EQUISOLID_ANGLE
Equisolid angle.
MFT_ORTHOGRAPHIC
Orthographic.
MFT_CUSTOM
custom
◆ MarkerType
enum MarkerType
Enumerator
MT_NONE
No type.
MT_BOX
Box geometry.
MT_CYLINDER
Cylinder geometry.
MT_LINE_STRIP
Line strip primitive.
MT_LINE_LIST
Line list primitive.
MT_POINTS
Points primitive.
MT_SPHERE
Sphere geometry.
MT_TEXT
Text geometry.
MT_TRIANGLE_FAN
Triangle fan primitive.
MT_TRIANGLE_LIST
Triangle list primitive.
MT_TRIANGLE_STRIP
Triangle strip primitive.
MT_CAPSULE
Capsule geometry.
◆ MaterialType
Enumerator
MT_CLASSIC
Classic shading, i.e. variants of Phong.
MT_PBS
Physically Based Shading.
◆ PixelFormat
PixelFormat.hh gz/rendering/PixelFormat.hh
Enumerator
PF_UNKNOWN
< Unknown or errant type
PF_L8
< Grayscale, 1-byte per channel
PF_R8G8B8
< RGB, 1-byte per channel
PF_B8G8R8
< BGR, 1-byte per channel
PF_BAYER_RGGB8
< Bayer RGGB, 1-byte per channel
PF_BAYER_BGGR8
< Bayer BGGR, 1-byte per channel
PF_BAYER_GBRG8
< Bayer GBRG, 1-byte per channel
PF_BAYER_GRBG8
< Bayer GRBG, 1-byte per channel
PF_FLOAT32_R
PF_FLOAT32_RGBA
PF_FLOAT32_RGB
PF_L16
PF_R8G8B8A8
< RGBA, 1-byte per channel
PF_COUNT
< Number of pixel format types
◆ SegmentationType
strong
Enumerator
ST_SEMANTIC
Pixels of same label from different items have the same color & id.
ST_PANOPTIC
Pixels of same label from different items, have different color & id. 1 channel for label id & 2 channels for instance id.
◆ ShaderType
enum ShaderType
ShaderType.hh gz/rendering/ShaderType.hh
Enumerator
ST_UNKNOWN
Unknown or errant type.
ST_PIXEL
Per pixel lighting shader.
ST_VERTEX
Per vertex lighting shader.
ST_NORM_OBJ
Object-space normal map shader.
ST_NORM_TAN
Tangent-space normal map shader.
ST_COUNT
Total number of shader types.
◆ TextHorizontalAlign
strong
Enumerator
LEFT
Left alignment.
CENTER
Center alignment.
RIGHT
Right alignment.
◆ TextVerticalAlign
strong
Enumerator
BOTTOM
Align bottom.
CENTER
Align center.
TOP
Align top.
◆ TransformAxis
Enumerator
TA_NONE
No axis.
TA_TRANSLATION_X
Translation in x.
TA_TRANSLATION_Y
Translation in y.
TA_TRANSLATION_Z
Translation in z.
TA_ROTATION_X
Rotation in x.
TA_ROTATION_Y
Rotation in y.
TA_ROTATION_Z
Rotation in z.
TA_SCALE_X
Scale in x.
TA_SCALE_Y
Scale in y.
TA_SCALE_Z
Scale in z.
◆ TransformMode
Enumerator
TM_NONE
Inactive state.
TM_TRANSLATION
Translation mode.
TM_ROTATION
Rotation mode.
TM_SCALE
Scale mode.
TA_SCALEZ
◆ TransformSpace
Enumerator
TS_LOCAL
transformation in local frame
TS_WORLD
transformation in world frame
Function Documentation
◆ convertRGBToBayer()
Image gz::rendering::convertRGBToBayer ( const Image &  _image,
[in]_imageInput RGB image
[in]_bayerFormatBayer format to convert to
Image in bayer format
◆ defaultGraphicsAPI()
GraphicsAPI gz::rendering::defaultGraphicsAPI ( )
Graphics API, i.e. METAL, OPENGL, VULKAN
◆ engine() [1/2]
RenderEngine* gz::rendering::engine ( const std::string &  _name,
const std::map< std::string, std::string > &  _params = {},
const std::string &  _path = ""
[in]_nameName of the desired render-engine
[in]_pathAnother search path for rendering engine plugin.
The specified render-engine
◆ engine() [2/2]
RenderEngine* gz::rendering::engine ( const unsigned int  _index,
[in]_indexIndex of the desired render-engine
◆ engineCount()
unsigned int gz::rendering::engineCount ( )
The number of available render-engines
◆ fini()
bool gz::rendering::fini ( )
True if successful
◆ getEngineInstallDir()
std::string gz::rendering::getEngineInstallDir ( )
◆ getInstallPrefix()
std::string gz::rendering::getInstallPrefix ( )
◆ getResourcePath()
std::string gz::rendering::getResourcePath ( )
◆ hasEngine()
bool gz::rendering::hasEngine ( const std::string &  _name)
True if a render-engine is registered under the given name
◆ init()
bool gz::rendering::init ( )
True if successful
◆ isEngineLoaded()
bool gz::rendering::isEngineLoaded ( const std::string &  _name)
True if a render-engine is loaded under the given name
◆ load()
bool gz::rendering::load ( )
True if successful
◆ loadedEngines()
std::vector<std::string> gz::rendering::loadedEngines ( )
All the engines currently loaded.
◆ projectionToCameraIntrinsic()
gz::math::Matrix3d gz::rendering::projectionToCameraIntrinsic ( const gz::math::Matrix4d &  _projectionMatrix,
double  _width,
double  _height
[in]_projectionMatrixCamera's projection matrix.
[in]_widthCamera's image width.
[in]_heightCamera's image height.
Camera's intrinsic matrix.
◆ registerEngine()
void gz::rendering::registerEngine ( const std::string &  _name,
RenderEngine *  _engine
[in]_nameName the render-engine will be registered under
[in]_engineRender-engine to be registered
◆ sceneFromFirstRenderEngine()
ScenePtr gz::rendering::sceneFromFirstRenderEngine ( )
It's not recommended to call this function when there's more than one engine or scene.
Pointer to a scene that was found, null if no scene is loaded.
◆ screenScalingFactor()
float gz::rendering::screenScalingFactor ( )
The screen scaling factor.
◆ screenToPlane()
math::Vector3d gz::rendering::screenToPlane ( const math::Vector2i &  _screenPos,
const CameraPtr &  _camera,
const RayQueryPtr &  _rayQuery,
const float  _offset = 0.0
[in]_screenPos2D coordinates on the screen, in pixels.
[in]_cameraUser camera
[in]_rayQueryRay query for mouse clicks
[in]_offsetOffset along the plane normal
3D coordinates of a point in the 3D scene.
◆ screenToScene() [1/2]
math::Vector3d gz::rendering::screenToScene ( const math::Vector2i &  _screenPos,
float  _maxDistance = 10.0
[in]_maxDistancemaximum distance to check the collision
◆ screenToScene() [2/2]
RayQueryResult &  _rayResult,
[in,out]_rayResultRay query result
◆ setPluginPaths()
void gz::rendering::setPluginPaths ( const std::list< std::string > &  _paths)
[in]_pathsThe list of the plugin paths
◆ transformAxisAlignedBox()
gz::math::AxisAlignedBox gz::rendering::transformAxisAlignedBox ( const gz::math::AxisAlignedBox &  _box,
const gz::math::Pose3d &  _pose
[in]_boxThe bounding box.
[in]_posePose used to transform the bounding box.
Vertices of the transformed bounding box in world coordinates.
◆ unloadEngine()
bool gz::rendering::unloadEngine ( const std::string &  _name)
True if the engine is unloaded
◆ unregisterEngine() [1/3]
void gz::rendering::unregisterEngine ( const std::string &  _name)
[in]_nameName of the render-engine to unregister
◆ unregisterEngine() [2/3]
void gz::rendering::unregisterEngine ( const unsigned int  _index)
[in]_indexIndex of the render-engine to unregister
◆ unregisterEngine() [3/3]
void gz::rendering::unregisterEngine ( RenderEngine *  _engine)
[in]_engineRender-engine to unregister
Variable Documentation
◆ depth_fragment_shader_file
Initial value:
"depth_fragment_shader.glsl"
◆ depth_vertex_shader_file
Initial value:
"depth_vertex_shader.glsl"
◆ kDefaultPbr
static
Referenced by BaseMaterial< OgreObject >::CopyFrom(), and BaseMaterial< OgreObject >::Reset().
