OgreGrid Class Reference
#include <OgreGrid.hh>
| virtual | ~OgreGrid () |
| Destructor. More... | |
| virtual void | Init () |
| virtual MaterialPtr | Material () const |
| virtual Ogre::MovableObject * | OgreObject () const |
| virtual void | PreRender () |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) |
Public Member Functions inherited from BaseGrid< OgreGeometry > | |
| virtual | ~BaseGrid () |
| virtual unsigned int | CellCount () const |
| Get the number of cells on a planar grid. More... | |
| virtual double | CellLength () const |
| Get the cell length. More... | |
| virtual void | Destroy () |
| virtual void | SetCellCount (const unsigned int _count) |
| Set the number of cells on a planar grid. More... | |
| virtual void | SetCellLength (const double _len) |
| Set the cell length in one direction. The cells are assumed to be square. More... | |
| virtual void | SetVerticalCellCount (const unsigned int _count) |
| Set the vertical cell count of the grid. This makes the grid 3D. More... | |
| virtual unsigned int | VerticalCellCount () const |
| Get the vertical cell count. More... | |
Public Member Functions inherited from Grid | |
| virtual | ~Grid () |
| virtual unsigned int | CellCount () const =0 |
| virtual double | CellLength () const =0 |
| virtual unsigned int | VerticalCellCount () const =0 |
| virtual | ~Geometry () |
Public Member Functions inherited from OgreGeometry | |
| virtual | ~OgreGeometry () |
| virtual bool | HasParent () const |
| virtual VisualPtr | Parent () const |
Public Member Functions inherited from BaseGeometry< OgreObject > | |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| OgreGrid () | |
| Constructor. More... | |
| virtual void | SetMaterialImpl (OgreMaterialPtr _material) |
| Set material to grid geometry. More... | |
Protected Member Functions inherited from BaseGrid< OgreGeometry > | |
| BaseGrid () | |
Protected Member Functions inherited from OgreGeometry | |
| OgreGeometry () | |
| virtual void | SetParent (OgreVisualPtr _parent) |
Protected Member Functions inherited from BaseGeometry< OgreObject > | |
| BaseGeometry () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseGrid< OgreGeometry > | |
| unsigned int | cellCount |
| Number of cells in grid. More... | |
| double | cellLength |
| Length of a single cell. More... | |
| bool | gridDirty |
| Flag to indicate grid properties have changed. More... | |
| double | heightOffset |
| vertical offset of the XY plane from origin More... | |
| unsigned int | verticalCellCount |
| Number of cells in vertical direction. More... | |
Protected Attributes inherited from OgreGeometry | |
| OgreVisualPtr | parent |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreGrid()
protected |
◆ ~OgreGrid()
virtual |
◆ Init()
virtual |
◆ Material()
virtual |
◆ OgreObject()
virtual |
Implements OgreGeometry.
◆ PreRender()
virtual |
Reimplemented from BaseGrid< OgreGeometry >.
◆ SetMaterial()
virtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Ogre material.
