#include <OgreGeometry.hh>
virtual ~OgreGeometry ()
virtual Ogre::MovableObject * OgreObject () const =0
virtual ~BaseGeometry ()
 Clone the geometry. More...
virtual void SetMaterial (MaterialPtr _material, bool _unique=true) override=0
 OgreGeometry ()
 BaseGeometry ()
virtual void Init ()
OgreVisualPtr parent
🔗OgreGeometry()
OgreGeometry ( )
🔗~OgreGeometry()
virtual ~OgreGeometry ( )
🔗HasParent()
Implements Geometry.
🔗OgreObject()
🔗Parent()
the parent Visual
🔗SetParent()
virtual void SetParent ( OgreVisualPtr  _parent)
🔗parent
