OgreWireBox Class Reference
Ogre implementation of a wire box geometry. More...
#include <OgreWireBox.hh>
| virtual | ~OgreWireBox () |
| Destructor. More... | |
| virtual MaterialPtr | Material () const override |
| virtual Ogre::MovableObject * | OgreObject () const override |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) override |
Public Member Functions inherited from BaseWireBox< OgreGeometry > | |
| virtual | ~BaseWireBox () |
| virtual gz::math::AxisAlignedBox | Box () const |
| Get the wireframe box. More... | |
| virtual void | Destroy () |
| virtual void | SetBox (const gz::math::AxisAlignedBox &_box) |
| Set the axis aligned box. More... | |
Public Member Functions inherited from WireBox | |
| virtual | ~WireBox () |
| virtual gz::math::AxisAlignedBox | Box () const =0 |
| virtual | ~Geometry () |
Public Member Functions inherited from OgreGeometry | |
| virtual | ~OgreGeometry () |
| virtual bool | HasParent () const |
| virtual VisualPtr | Parent () const |
Public Member Functions inherited from BaseGeometry< OgreObject > | |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| OgreWireBox () | |
| Constructor. More... | |
| virtual void | SetMaterialImpl (OgreMaterialPtr _material) |
| Set material to wire box geometry. More... | |
Protected Member Functions inherited from BaseWireBox< OgreGeometry > | |
| BaseWireBox () | |
Protected Member Functions inherited from WireBox | |
| WireBox () | |
Protected Member Functions inherited from OgreGeometry | |
| OgreGeometry () | |
| virtual void | SetParent (OgreVisualPtr _parent) |
Protected Member Functions inherited from BaseGeometry< OgreObject > | |
| BaseGeometry () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseWireBox< OgreGeometry > | |
| gz::math::AxisAlignedBox | box |
| bool | wireBoxDirty |
| Flag to indicate WireBox properties have changed. More... | |
Protected Attributes inherited from OgreGeometry | |
| OgreVisualPtr | parent |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreWireBox()
protected |
◆ ~OgreWireBox()
virtual |
◆ Init()
overridevirtual |
◆ Material()
overridevirtual |
◆ OgreObject()
overridevirtual |
Implements OgreGeometry.
◆ PreRender()
overridevirtual |
Reimplemented from BaseWireBox< OgreGeometry >.
◆ SetMaterial()
overridevirtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Ogre material.
