Visual Class Referenceabstract
Represents a visual node in a scene graph. A Visual is the only node that can have Geometry and other Visual children. More...
#include <gz/rendering/Visual.hh>
◆ ~Visual()
virtual ~Visual ( )
◆ AddGeometry()
virtual void AddGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be added
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
◆ AddVisibilityFlags()
virtual void AddVisibilityFlags ( uint32_t  _flags)
[in]_flagsVisibility flags
◆ BoundingBox()
virtual gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implemented in BaseVisual< T >, OgreVisual, and Ogre2Visual.
◆ Clone()
virtual VisualPtr Clone ( const std::string &  _name,
NodePtr  _newParent
) const
[in]_nameName of the cloned Visual. Set this to an empty string to auto-generate a unique name for the cloned visual.
[in]_newParentParent of the cloned Visual. Set to nullptr if the cloned visual should have no parent.
The visual. nullptr is returned if cloning failed.
◆ GeometryByIndex()
virtual GeometryPtr GeometryByIndex ( unsigned int  _index) const
[in]_indexIndex of the desired geometry
The specified geometry
◆ GeometryCount()
virtual unsigned int GeometryCount ( ) const
The number of geometries attached to this visual
Implemented in BaseVisual< T >.
◆ HasGeometry()
virtual bool HasGeometry ( ConstGeometryPtr  _geometry) const
[in]_geometryGeometry in question
True if given node is attached to this visual
◆ LocalBoundingBox()
virtual gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implemented in BaseVisual< T >, Ogre2Visual, and OgreVisual.
Implemented in BaseParticleEmitter< T >, BaseVisual< T >, OgreInertiaVisual, Ogre2InertiaVisual, OgreCOMVisual, Ogre2COMVisual, OgreLightVisual, Ogre2LightVisual, and ParticleEmitter.
◆ RemoveGeometries()
virtual void RemoveGeometries ( )
◆ RemoveGeometry()
virtual GeometryPtr RemoveGeometry ( GeometryPtr  _geometry)
[in]_geometryGeometry to be removed
The removed geometry
◆ RemoveGeometryByIndex()
virtual GeometryPtr RemoveGeometryByIndex ( unsigned int  _index)
[in]_indexIndex of the geometry to be removed
◆ RemoveVisibilityFlags()
virtual void RemoveVisibilityFlags ( uint32_t  _flags)
◆ SetChildMaterial()
virtual void SetChildMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetGeometryMaterial()
virtual void SetGeometryMaterial ( MaterialPtr  _material,
bool  _unique = true
◆ SetMaterial() [1/2]
bool  _unique = true
[in]_nameName of the material to be assigned
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, OgreInertiaVisual, Ogre2InertiaVisual, OgreCOMVisual, Ogre2COMVisual, OgreLightVisual, and Ogre2LightVisual.
◆ SetVisibilityFlags()
Implemented in BaseVisual< T >, BaseVisual< Ogre2Node >, BaseVisual< OgreNode >, Ogre2Visual, and OgreVisual.
◆ SetVisible()
◆ SetWireframe()
◆ VisibilityFlags()
virtual uint32_t VisibilityFlags ( ) const
visibility flags
◆ Wireframe()
