Node Class Referenceabstract
#include <gz/rendering/Node.hh>
◆ ~Node()
virtual ~Node ( )
◆ AddChild()
virtual void AddChild ( NodePtr  _child)
[in]_childChild node to be added
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, and BaseNode< OgreObject >.
◆ ChildById()
virtual NodePtr ChildById ( unsigned int  _id) const
[in]_idID of the desired node
The specified node
◆ ChildByIndex()
virtual NodePtr ChildByIndex ( unsigned int  _index) const
The specified node
◆ ChildByName()
virtual NodePtr ChildByName ( const std::string &  _name) const
The specified node
◆ ChildCount()
virtual unsigned int ChildCount ( ) const
The number of child nodes
Implemented in BaseNode< T >.
◆ HasChild()
virtual bool HasChild ( ConstNodePtr  _child) const
True if given node is an attached child
◆ HasChildId()
virtual bool HasChildId ( unsigned int  _id) const
True if node with given ID is an attached child
◆ HasChildName()
virtual bool HasChildName ( const std::string &  _name) const
True if node with given name is an attached child
◆ HasParent()
Implemented in Ogre2Node, and OgreNode.
◆ HasUserData()
virtual bool HasUserData ( const std::string &  _key) const
[in]_keyUnique key
True if node has custom data with the specified key
◆ InheritScale()
Implemented in BaseNode< T >, Ogre2Node, and OgreNode.
◆ InitialLocalPose()
virtual math::Pose3d InitialLocalPose ( ) const
The initial local pose
◆ LocalPose()
virtual math::Pose3d LocalPose ( ) const
Get the local pose.
The local pose
Implemented in BaseNode< T >, and BaseVisual< T >.
◆ LocalPosition()
virtual math::Vector3d LocalPosition ( ) const
The local position
◆ LocalRotation()
virtual math::Quaterniond LocalRotation ( ) const
The local rotation
◆ LocalScale()
The local scale
Implemented in BaseNode< T >, Ogre2Node, OgreNode, and BaseAxisVisual< T >.
◆ Origin()
virtual math::Vector3d Origin ( ) const
The position of the origin
◆ Parent()
the parent Node
◆ RemoveChild()
virtual NodePtr RemoveChild ( NodePtr  _child)
[in]_childChild node to be removed
The removed child node
◆ RemoveChildById()
virtual NodePtr RemoveChildById ( unsigned int  _id)
[in]_idID of the child node to be removed
◆ RemoveChildByIndex()
virtual NodePtr RemoveChildByIndex ( unsigned int  _index)
[in]_indexIndex of the child node to be removed
◆ RemoveChildByName()
virtual NodePtr RemoveChildByName ( const std::string &  _name)
[in]_nameName of the child node to be removed
◆ RemoveChildren()
virtual void RemoveChildren ( )
◆ RemoveParent()
virtual void RemoveParent ( )
◆ Scale() [1/3]
virtual void Scale ( const math::Vector3d &  _scale)
[in]_scaleScalars to alter the current scale
◆ Scale() [2/3]
virtual void Scale ( double  _scale)
[in]_scaleScalar to alter the current scale
◆ Scale() [3/3]
virtual void Scale ( double  _x,
double  _y,
double  _z
[in]_xScalar to alter the current x-coordinate scale
[in]_yScalar to alter the current y-coordinate scale
[in]_zScalar to alter the current z-coordinate scale
◆ SetInheritScale()
[in]_inheritTrue if this node inherits scale from its parent
◆ SetLocalPose()
virtual void SetLocalPose ( const math::Pose3d &  _pose)
Set the local pose.
[in]_poseNew local pose
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, BaseNode< OgreObject >, BaseVisual< T >, BaseVisual< Ogre2Node >, and BaseVisual< OgreNode >.
◆ SetLocalPosition() [1/2]
virtual void SetLocalPosition ( const math::Vector3d &  _position)
[in]_positionNew local position
◆ SetLocalPosition() [2/2]
virtual void SetLocalPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetLocalRotation() [1/3]
virtual void SetLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew local rotation
◆ SetLocalRotation() [2/3]
virtual void SetLocalRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
◆ SetLocalRotation() [3/3]
virtual void SetLocalRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetLocalScale() [1/3]
virtual void SetLocalScale ( const math::Vector3d &  _scale)
[in]_scaleNew local scale
Implemented in BaseNode< T >, BaseNode< Ogre2Object >, BaseNode< OgreObject >, BaseAxisVisual< T >, BaseAxisVisual< OgreVisual >, and BaseAxisVisual< Ogre2Visual >.
◆ SetLocalScale() [2/3]
virtual void SetLocalScale ( double  _scale)
◆ SetLocalScale() [3/3]
virtual void SetLocalScale ( double  _x,
double  _y,
double  _z
[in]_xNew x-coordinate scale
[in]_yNew y-coordinate scale
[in]_zNew z-coordinate scale
◆ SetOrigin() [1/2]
virtual void SetOrigin ( const math::Vector3d &  _origin)
[in]_originNew origin position
◆ SetOrigin() [2/2]
virtual void SetOrigin ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetUserData()
virtual void SetUserData ( const std::string &  _key,
Variant  _value
[in]_keyUnique key
[in]_valueValue in any type
◆ SetWorldPose()
virtual void SetWorldPose ( const math::Pose3d &  _pose)
Set the world pose.
[in]_poseNew world pose
◆ SetWorldPosition() [1/2]
virtual void SetWorldPosition ( const math::Vector3d &  _position)
[in]_positionNew world position
◆ SetWorldPosition() [2/2]
virtual void SetWorldPosition ( double  _x,
double  _y,
double  _z
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetWorldRotation() [1/3]
virtual void SetWorldRotation ( const math::Quaterniond &  _rotation)
[in]_rotationNew world rotation
◆ SetWorldRotation() [2/3]
virtual void SetWorldRotation ( double  _r,
double  _p,
double  _y
[in]_rroll
[in]_ppitch
[in]_yyaw
◆ SetWorldRotation() [3/3]
virtual void SetWorldRotation ( double  _w,
double  _x,
double  _y,
double  _z
[in]_wW-coordinate
[in]_xX-coordinate
[in]_yY-coordinate
[in]_zZ-coordinate
◆ SetWorldScale() [1/3]
virtual void SetWorldScale ( const math::Vector3d &  _scale)
[in]_scaleNew world scale
◆ SetWorldScale() [2/3]
virtual void SetWorldScale ( double  _scale)
◆ SetWorldScale() [3/3]
virtual void SetWorldScale ( double  _x,
double  _y,
double  _z
◆ UserData()
virtual Variant UserData ( const std::string &  _key) const
[in]_keyUnique key
Value in any type. If _key does not exist for the node, an empty variant is returned (i.e., no data).
◆ WorldPose()
virtual math::Pose3d WorldPose ( ) const
Get the world pose.
The world pose
◆ WorldPosition()
virtual math::Vector3d WorldPosition ( ) const
The world position
◆ WorldRotation()
virtual math::Quaterniond WorldRotation ( ) const
The world rotation
◆ WorldScale()
virtual math::Vector3d WorldScale ( ) const
The world scale
◆ WorldToLocal()
virtual math::Pose3d WorldToLocal ( const math::Pose3d &  _pose) const
[in]_poseWorld pose to be converted
