Ogre2.x implementation of the Node class. More...
#include <Ogre2Node.hh>
virtual ~Ogre2Node ()
 Ogre2Node ()
 Set the parent node. More...
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Node()
Ogre2Node ( )
◆ ~Ogre2Node()
virtual ~Ogre2Node ( )
◆ AttachChild()
◆ Children()
virtual NodeStorePtr Children ( ) const
◆ DetachChild()
virtual bool DetachChild ( NodePtr  _child)
◆ HasParent()
Implements Node.
◆ InheritScale()
Implements Node.
◆ Load()
virtual void Load ( )
Reimplemented in BaseCamera< Ogre2Sensor >.
◆ LocalScale()
The local scale
Implements Node.
◆ Node()
virtual Ogre::SceneNode* Node ( ) const
Ogre scene node pointer
◆ Parent()
the parent Node
Implements Node.
◆ RawLocalPose()
◆ RawLocalPosition()
virtual math::Vector3d RawLocalPosition ( ) const
Local position
◆ RawLocalRotation()
virtual math::Quaterniond RawLocalRotation ( ) const
Local rotation
◆ SetInheritScale()
[in]_inheritTrue if this node inherits scale from its parent
Implements Node.
◆ SetLocalScaleImpl()
Implements BaseNode< Ogre2Object >.
◆ SetParent()
virtual void SetParent ( Ogre2NodePtr  _parent)
[in]_parentThe parent ogre node
◆ SetRawLocalPose()
virtual void SetRawLocalPose ( const math::Pose3d &  _Pose3d)
◆ SetRawLocalPosition()
virtual void SetRawLocalPosition ( const math::Vector3d &  _position)
[in]_positionLocal position to set the node to
◆ SetRawLocalRotation()
virtual void SetRawLocalRotation ( const math::Quaterniond &  _rotation)
[in]_rotationLocal rotation to set the node to
◆ children
◆ ogreNode
Ogre::SceneNode* ogreNode = nullptr
◆ parent
Ogre2NodePtr parent
