Ogre2BoundingBoxCamera Class Reference
BoundingBox camera used to detect 2d / 3d bounding boxes of labeled objects in the scene. More...
#include <Ogre2BoundingBoxCamera.hh>
virtual ~Ogre2BoundingBoxCamera ()
virtual const std::vector< BoundingBox > & BoundingBoxData () const override
 Get the BoundingBox data. More...
void BoundingBoxes3D ()
 Compute the 3D bounding boxes. More...
virtual common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)>) override
 Connect to the new BoundingBox info. More...
void ConvertToScreenCoord (Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex) const
 Convert from clip coord (after projection) to screen coord. More...
void CreateBoundingBoxTexture ()
 Create texture to hold ogre Ids to calculate the boundaries of each ogre id mask. More...
void CreateRenderTexture ()
 Create dummy render texture. Needed to satisfy inheritance and to set image's dims. More...
 Destroy the camera. More...
virtual void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const override
 Draw a bounding box on the given image. More...
void DrawLine (unsigned char *_data, const math::Vector2i &_point1, const math::Vector2i &_point2, const math::Color &_color) const
 Draw line between any 2 points in the image data buffer Algorithm: https://en.wikipedia.org/wiki/Bresenham%27s_line_algorithm. More...
void FullBoundingBoxes ()
 Compute the full bounding boxes by projecting all mesh vertices of each object, then get the min & max of x & y to get the full bbox. Check the visibility by looping over pixels of the ogre Ids map. More...
 Initialize the camera. More...
void MarkVisibleBoxes ()
 Mark the visible boxes by checking the ogre ids map and mark the ogre id which appears in the map. More...
void MeshMinimalBox (const Ogre::MeshPtr _mesh, const Ogre::Matrix4 &_viewMatrix, const Ogre::Matrix4 &_projMatrix, Ogre::Vector3 &_minVertex, Ogre::Vector3 &_maxVertex, const Ogre::Vector3 &_position, const Ogre::Quaternion &_orientation, const Ogre::Vector3 &_scale)
 Get minimal bounding box of the mesh by projecting the 3d vertices of the vertex buffer to 2d, then get the min & max of x & y. More...
virtual void SetBoundingBoxType (BoundingBoxType _type) override
 Set BoundingBox Type (Visible / Full) More...
virtual BoundingBoxType Type () const override
 Get the BoundingBox Type (Visible / Full) More...
void VisibleBoundingBoxes ()
 Compute the visible bounding boxes by looping over pixels of the ogre Ids map, to get the boundaries of each unique ogre Id mask. More...
- Public Member Functions inherited from BaseBoundingBoxCamera< Ogre2Sensor >
virtual ~BaseBoundingBoxCamera ()
- Public Member Functions inherited from BoundingBoxCamera
virtual ~BoundingBoxCamera ()
virtual ~Camera ()
 Sensor. More...
 Get visibility mask. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
virtual ~Ogre2Node ()
- Protected Member Functions inherited from BaseBoundingBoxCamera< Ogre2Sensor >
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseBoundingBoxCamera< Ogre2Sensor >
std::vector< BoundingBox > boundingBoxes
 The bounding box data. More...
BoundingBoxType type
 The bounding box type. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2BoundingBoxCamera()
Ogre2BoundingBoxCamera ( )
◆ ~Ogre2BoundingBoxCamera()
virtual ~Ogre2BoundingBoxCamera ( )
◆ BoundingBoxData()
virtual const std::vector<BoundingBox>& BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implements BoundingBoxCamera.
◆ BoundingBoxes3D()
void BoundingBoxes3D ( )
◆ ConnectNewBoundingBoxes()
virtual common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
Implements BaseBoundingBoxCamera< Ogre2Sensor >.
◆ ConvertToScreenCoord()
void ConvertToScreenCoord ( Ogre::Vector3 &  _minVertex,
Ogre::Vector3 &  _maxVertex
) const
[in,out]_minVertexmin vertex in clip coord to screen coord
[in,out]_maxVertexmax vertex in clip coord to screen coord
◆ CreateBoundingBoxTexture()
void CreateBoundingBoxTexture ( )
◆ CreateRenderTexture()
void CreateRenderTexture ( )
Destroy the camera.
Reimplemented from Ogre2Node.
◆ DrawBoundingBox()
virtual void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
◆ DrawLine()
void DrawLine ( unsigned char *  _data,
const math::Vector2i &  _point1,
const math::Vector2i &  _point2,
) const
[in]_databuffer contains the image data
[in]_point1The 1st 2D point in screen coordinates
[in]_point2The 2nd 2D point in screen coordinates
[in]_colorThe color of the line
◆ FullBoundingBoxes()
void FullBoundingBoxes ( )
◆ MarkVisibleBoxes()
void MarkVisibleBoxes ( )
◆ MeshMinimalBox()
void MeshMinimalBox ( const Ogre::MeshPtr  _mesh,
const Ogre::Matrix4 &  _viewMatrix,
const Ogre::Matrix4 &  _projMatrix,
Ogre::Vector3 &  _maxVertex,
const Ogre::Vector3 &  _position,
const Ogre::Quaternion &  _orientation,
const Ogre::Vector3 &  _scale
[in]_meshMesh of the item to get its minimal bbox
[in]_viewMatrixCamera view matrix
[in]_projMatrixCamera projection matrix
[out]_minVertexMinimum of projected x & y & z of the vertices
[out]_maxVertexMaximum of projected x & y & z of the vertices
[in]_positionposition of the item in the world space
[in]_orientationrotation of the item
[in]_scalescale of the item
◆ PostRender()
virtual void PostRender ( )
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
◆ SetBoundingBoxType()
virtual void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
Reimplemented from BaseBoundingBoxCamera< Ogre2Sensor >.
◆ Type()
virtual BoundingBoxType Type ( ) const
◆ VisibleBoundingBoxes()
void VisibleBoundingBoxes ( )
