BoundingBoxCamera Class Referenceabstract
Poseable BoundingBox camera used for rendering bounding boxes of objects in the scene. More...
#include <BoundingBoxCamera.hh>
virtual ~BoundingBoxCamera ()
virtual const std::vector< BoundingBox > & BoundingBoxData () const =0
 Get the BoundingBox data. More...
virtual gz::common::ConnectionPtr ConnectNewBoundingBoxes (std::function< void(const std::vector< BoundingBox > &)> _subscriber)=0
 Connect to the new BoundingBox info. More...
virtual void DrawBoundingBox (unsigned char *_data, const math::Color &_color, const BoundingBox &_box) const =0
 Draw a bounding box on the given image. More...
virtual void SetBoundingBoxType (BoundingBoxType _type)=0
 Set BoundingBox Type (Visible / Full) More...
virtual BoundingBoxType Type () const =0
 Get the BoundingBox Type (Visible / Full) More...
virtual ~Camera ()
virtual void Render ()=0
virtual void RenderTextureMetalId (void *_textureIdPtr) const =0
virtual void SetImageFormat (PixelFormat _format)=0
virtual void Update ()=0
virtual VisualPtr VisualAt (const gz::math::Vector2i &_mousePos)=0
 Sensor. More...
 Set visibility mask. More...
 Get visibility mask. More...
gz/rendering/BoundingBoxCamera.hh
◆ ~BoundingBoxCamera()
virtual ~BoundingBoxCamera ( )
◆ BoundingBoxData()
virtual const std::vector<BoundingBox>& BoundingBoxData ( ) const
Buffer of bounding boxes info (label, minX, minY, maxX, maxY). If the camera's bounding box type is 3D, minZ and maxZ are also defined)
Implemented in Ogre2BoundingBoxCamera, and BaseBoundingBoxCamera< T >.
◆ ConnectNewBoundingBoxes()
virtual gz::common::ConnectionPtr ConnectNewBoundingBoxes ( std::function< void(const std::vector< BoundingBox > &)>  _subscriber)
Implemented in Ogre2BoundingBoxCamera, BaseBoundingBoxCamera< T >, and BaseBoundingBoxCamera< Ogre2Sensor >.
◆ DrawBoundingBox()
virtual void DrawBoundingBox ( unsigned char *  _data,
const math::Color &  _color,
const BoundingBox &  _box
) const
[in]_databuffer containing the image data
[in]_colorColor of the bounding box to be drawn
[in]_boxbounding box to be drawn
Implemented in BaseBoundingBoxCamera< Ogre2Sensor >, Ogre2BoundingBoxCamera, and BaseBoundingBoxCamera< T >.
◆ SetBoundingBoxType()
virtual void SetBoundingBoxType ( BoundingBoxType  _type)
[in]_typeBoundingBox Type (Visible / Full)
◆ Type()
virtual BoundingBoxType Type ( ) const
