Ogre2.x implementation of the sensor classs. More...
#include <Ogre2Sensor.hh>
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
 Get visibility mask. More...
 Sensor. More...
virtual ~Ogre2Node ()
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Sensor()
Ogre2Sensor ( )
◆ ~Ogre2Sensor()
virtual ~Ogre2Sensor ( )
