RenderTarget Class Referenceabstract
#include <gz/rendering/RenderTarget.hh>
virtual ~RenderTarget ()
◆ ~RenderTarget()
virtual ~RenderTarget ( )
◆ AddRenderPass()
Implemented in BaseRenderTarget< T >, BaseRenderTarget< Ogre2Object >, and BaseRenderTarget< OgreObject >.
Referenced by BaseCamera< OgreSensor >::AddRenderPass().
◆ BackgroundColor()
Implemented in Ogre2RenderTarget, BaseRenderTarget< T >, and OgreRenderTarget.
◆ Copy()
Implemented in Ogre2RenderTarget, and OgreRenderTarget.
Referenced by BaseCamera< OgreSensor >::Copy().
◆ Format()
virtual PixelFormat Format ( ) const
Render target format
Implemented in BaseRenderTarget< T >.
Referenced by BaseCamera< OgreSensor >::ImageFormat().
◆ Height()
virtual unsigned int Height ( ) const
Referenced by BaseCamera< OgreSensor >::ImageHeight().
◆ RemoveRenderPass()
Referenced by BaseCamera< OgreSensor >::RemoveRenderPass().
◆ RenderPassByIndex()
Referenced by BaseCamera< OgreSensor >::RenderPassByIndex().
◆ RenderPassCount()
Referenced by BaseCamera< OgreSensor >::RenderPassCount().
◆ SetFormat()
virtual void SetFormat ( PixelFormat  _format)
[in]_formatNew target format
Referenced by BaseCamera< OgreSensor >::SetImageFormat().
◆ SetHeight()
virtual void SetHeight ( const unsigned int  _height)
Referenced by BaseCamera< OgreSensor >::SetImageHeight().
◆ SetWidth()
virtual void SetWidth ( const unsigned int  _width)
Referenced by BaseCamera< OgreSensor >::SetImageWidth().
◆ Width()
virtual unsigned int Width ( ) const
Referenced by BaseCamera< OgreSensor >::ImageWidth().
