Ogre2.x implementation of the visual class. More...
#include <Ogre2Visual.hh>
virtual ~Ogre2Visual ()
virtual ~BaseVisual ()
virtual ~Ogre2Node ()
 Ogre2Visual ()
 BaseVisual ()
 Ogre2Node ()
 Set the parent node. More...
uint32_t visibilityFlags
bool wireframe
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Visual()
Ogre2Visual ( )
◆ ~Ogre2Visual()
virtual ~Ogre2Visual ( )
◆ AttachGeometry()
◆ BoundingBox()
virtual gz::math::AxisAlignedBox BoundingBox ( ) const
The axis aligned bounding box
Implements Visual.
◆ DetachGeometry()
◆ Geometries()
◆ LocalBoundingBox()
virtual gz::math::AxisAlignedBox LocalBoundingBox ( ) const
The local bounding box
Implements Visual.
◆ SetVisibilityFlags()
[in]_flagsVisibility flags
Reimplemented from BaseVisual< Ogre2Node >.
◆ SetVisible()
Reimplemented in BaseJointVisual< Ogre2Visual >, Ogre2LidarVisual, BaseArrowVisual< Ogre2Visual >, and BaseAxisVisual< Ogre2Visual >.
◆ SetWireframe()
◆ Wireframe()
Implements Visual.
◆ geometries
