Thermal camera used to render thermal data into an image buffer. More...
#include <Ogre2ThermalCamera.hh>
virtual ~Ogre2ThermalCamera ()
virtual gz::common::ConnectionPtr ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber) override
 Connect to the new thermal image event. More...
 Initialize the camera. More...
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object. More...
 Render the camera. More...
- Public Member Functions inherited from BaseThermalCamera< Ogre2Sensor >
virtual ~BaseThermalCamera ()
virtual float AmbientTemperature () const override
 Get the ambient temperature of the environment. More...
virtual float AmbientTemperatureRange () const override
 Get the range of ambient temperature. More...
virtual float HeatSourceTemperatureRange () const override
 Get the range of temperature variation for all heat sources. More...
virtual float LinearResolution () const override
 Get the temperature linear resolution. More...
virtual float MaxTemperature () const override
 Get the maximum temperature the sensor can detect. More...
virtual float MinTemperature () const override
 Get the minimum temperature the sensor can detect. More...
virtual void SetAmbientTemperature (float _ambient) override
 Set the ambient temperature of the environment. More...
virtual void SetAmbientTemperatureRange (float _range) override
 Set the range of ambient temperature. More...
virtual void SetHeatSourceTemperatureRange (float _range) override
 Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source. More...
virtual void SetLinearResolution (float _max) override
 Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More...
virtual void SetMaxTemperature (float _max) override
 Set the maximum temperature the sensor can detect. More...
virtual void SetMinTemperature (float _min) override
 Set the minimum temperature the sensor can detect. More...
- Public Member Functions inherited from ThermalCamera
virtual ~ThermalCamera ()
virtual float AmbientTemperature () const =0
virtual float AmbientTemperatureRange () const =0
virtual float HeatSourceTemperatureRange () const =0
virtual float LinearResolution () const =0
virtual float MaxTemperature () const =0
virtual float MinTemperature () const =0
virtual ~Camera ()
 Sensor. More...
 Get visibility mask. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
 Set visibility mask. More...
virtual ~Ogre2Node ()
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject. More...
void CreateCamera ()
 Create the camera. More...
 Create dummy render texture. Needed to satisfy inheritance. More...
virtual void CreateThermalTexture ()
 Create thermal texture. More...
- Protected Member Functions inherited from BaseThermalCamera< Ogre2Sensor >
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
- Protected Attributes inherited from BaseThermalCamera< Ogre2Sensor >
float ambient
 Ambient temperature of the environment. More...
float ambientRange
 Ambient temperature range. More...
float heatSourceTempRange
 Range of heat source temperature variation. More...
float maxTemp
 Maximum temperature. More...
float minTemp
 Minimum temperature. More...
float resolution
 Linear resolution. Defaults to 10mK. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2ThermalCamera()
Ogre2ThermalCamera ( )
◆ ~Ogre2ThermalCamera()
virtual ~Ogre2ThermalCamera ( )
◆ ConnectNewThermalFrame()
virtual gz::common::ConnectionPtr ConnectNewThermalFrame ( std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)>  _subscriber)
Reimplemented from BaseThermalCamera< Ogre2Sensor >.
◆ CreateCamera()
void CreateCamera ( )
Create the camera.
◆ CreateRenderTexture()
◆ CreateThermalTexture()
virtual void CreateThermalTexture ( )
Reimplemented from Ogre2Node.
◆ OgreCamera()
virtual Ogre::Camera* OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ PostRender()
virtual void PostRender ( )
Render the camera.
Reimplemented from BaseCamera< Ogre2Sensor >.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
Pointer to the render target
◆ ogreCamera
