#include <ThermalCamera.hh>
| Destructor. More... | |
| Get the ambient temperature of the environment. More... | |
| Get the range of ambient temperature. More... | |
| virtual gz::common::ConnectionPtr | ConnectNewThermalFrame (std::function< void(const uint16_t *, unsigned int, unsigned int, unsigned int, const std::string &)> _subscriber)=0 |
| Connect to the new thermal image event. More... | |
| Get the range of temperature variation for all heat sources. More... | |
| Get the temperature linear resolution. More... | |
| Get the maximum temperature the sensor can detect. More... | |
| Get the minimum temperature the sensor can detect. More... | |
| virtual void | SetAmbientTemperature (float _ambient)=0 |
| Set the ambient temperature of the environment. More... | |
| virtual void | SetAmbientTemperatureRange (float _range)=0 |
| Set the range of ambient temperature. More... | |
| virtual void | SetHeatSourceTemperatureRange (float _range)=0 |
| Set the range of temperature variation for all heat sources. If set, the temperature reading of heat sources will vary within a temperature of +/- range/2 instead of returning a fixed uniform temperature for the entire heat source. More... | |
| virtual void | SetLinearResolution (float _resolution)=0 |
| Set the temperature linear resolution. The thermal image data returned will be temperature in kelvin / resolution. Typical values are 0.01 (10mK), 0.1 (100mK), or 0.04 to simulate 14 bit format. More... | |
| virtual void | SetMaxTemperature (float _max)=0 |
| Set the maximum temperature the sensor can detect. More... | |
| virtual void | SetMinTemperature (float _min)=0 |
| Set the minimum temperature the sensor can detect. More... | |
| virtual | ~Camera () |
| Renders a new frame and writes the results to the given image. This is a convenience function for single-camera scenes. It wraps the pre-render, render, post-render, and get-image calls into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual void | RenderTextureMetalId (void *_textureIdPtr) const =0 |
| Get the Metal texture id associated with the render texture used by this camera. A valid Id is obtained only if the underlying render engine is Metal based. The pointer set by this function must be released to an id<MTLTexture> using CFBridgingRelease. More... | |
| Renders a new frame. This is a convenience function for single-camera scenes. It wraps the pre-render, render, and post-render into a single function. This should NOT be used in applications with multiple cameras or multiple consumers of a single camera's images. More... | |
| virtual | ~Sensor () |
| Sensor. More... | |
| virtual | ~Node () |
◆ ~ThermalCamera()
virtual |
◆ AmbientTemperature()
pure virtual |
- Returns
- Ambient temperature in kelvin
- See also
- SetAmbientTemperature
Implemented in BaseThermalCamera< T >.
◆ AmbientTemperatureRange()
pure virtual |
- Returns
- The ambient temperature range. Ambient temperature ranges from (ambient - range/2) to (ambient - range/2)
- See also
- SetAmbientTemperatureRange
◆ ConnectNewThermalFrame()
pure virtual |
[in] _subscriber Subscriber callback function. The callback function arguments are: <thermal data, width, height, depth, format>
- Returns
Implemented in OgreThermalCamera, BaseThermalCamera< T >, Ogre2ThermalCamera, BaseThermalCamera< Ogre2Sensor >, and BaseThermalCamera< OgreSensor >.
◆ HeatSourceTemperatureRange()
pure virtual |
- Returns
- Temperature variation range
- See also
- SetHeatSourceTemperatureRange
◆ LinearResolution()
pure virtual |
- Returns
- Temperature linear resolution
- See also
- SetLinearResolution
◆ MaxTemperature()
pure virtual |
- Returns
- Max temperature in kelvin
- See also
- SetMaxTemperature
◆ MinTemperature()
pure virtual |
- Returns
- Min temperature in kelvin
- See also
- SetMinTemperature
◆ SetAmbientTemperature()
pure virtual |
[in] _ambient Ambient temperature in kelvin
- See also
- AmbientTemperature
Implemented in BaseThermalCamera< T >, BaseThermalCamera< Ogre2Sensor >, and BaseThermalCamera< OgreSensor >.
◆ SetAmbientTemperatureRange()
pure virtual |
[in] _range The ambient temperature ranges from (ambient - range/2) to (ambient + range/2).
- See also
- AmbientTemperatureRange
◆ SetHeatSourceTemperatureRange()
pure virtual |
[in] _range Temperature variation range
- See also
- HeatSourceTemperatureRange
◆ SetLinearResolution()
pure virtual |
[in] _resolution Temperature linear resolution
- See also
- LinearResolution
◆ SetMaxTemperature()
pure virtual |
[in] _max Max temperature in kelvin
- See also
- MaxTemperature
◆ SetMinTemperature()
pure virtual |
[in] _min Min temperature in kelvin
- See also
- MinTemperature
