Ogre2.x implementation of the camera class. More...
#include <Ogre2Camera.hh>
virtual ~Ogre2Camera ()
virtual math::Color BackgroundColor () const
virtual MaterialPtr BackgroundMaterial () const
 Get the background material of this camera. More...
virtual Ogre::Camera * OgreCamera () const override
 Access the Ogre::Camera object. More...
Ogre2SelectionBuffer * SelectionBuffer () const
 Get the selection buffer object. More...
virtual void SetBackgroundColor (const math::Color &_color)
virtual void SetBackgroundMaterial (MaterialPtr _material)
 Set the background material of this camera. More...
void SetShadowsDirty () override
 Set visibility mask. More...
- Public Member Functions inherited from BaseCamera< Ogre2Sensor >
virtual ~BaseCamera ()
virtual ~Camera ()
 Sensor. More...
 Get visibility mask. More...
virtual ~Ogre2Sensor ()
virtual ~BaseSensor ()
virtual ~Ogre2Node ()
- Public Member Functions inherited from Ogre2ObjectInterface
virtual ~Ogre2ObjectInterface ()
 Access to an Ogre::MovableObject. More...
 Ogre2Camera ()
 Create a render texture for the camera for offscreen rendering. More...
void DestroyRenderTexture ()
 Destroy render texture created by CreateRenderTexture() Note: It's not virtual. More...
virtual void SetSelectionBuffer ()
 Create and set selection buffer object TODO(anyone) to be implemented. More...
void SyncOgreCameraAspectRatio ()
 Synchronizes every setting that depends on AspectRatio with Ogre's camera. More...
- Protected Member Functions inherited from BaseCamera< Ogre2Sensor >
 BaseCamera ()
virtual RenderTargetPtr RenderTarget () const=0
 Ogre2Sensor ()
 BaseSensor ()
 Ogre2Node ()
 Set the parent node. More...
math::Color backgroundColor
 Color of background. More...
 Pointer to ogre camera object. More...
Ogre2RenderTargetPtr renderTexture
 Pointer to render texture. More...
Ogre2SelectionBuffer * selectionBuffer = nullptr
 Selection buffer object for entity picking. More...
- Protected Attributes inherited from BaseCamera< Ogre2Sensor >
unsigned int antiAliasing
 Anti-aliasing. More...
double aspect
 Aspect ratio. More...
double farClip
NodePtr followNode
math::Vector3d followOffset
double followPGain
bool followWorldFrame
math::Angle hfov
ImagePtr imageBuffer
double nearClip
NodePtr trackNode
math::Vector3d trackOffset
double trackPGain
bool trackWorldFrame
uint32_t visibilityMask
Ogre2NodeStorePtr children
Ogre2NodePtr parent
◆ Ogre2Camera()
Ogre2Camera ( )
◆ ~Ogre2Camera()
virtual ~Ogre2Camera ( )
◆ AntiAliasing()
Implements Camera.
◆ AspectRatio()
Remarks
If SetAspectRatio() gets called with an input <= 0 this function returns the Aspect Ratio autocalculated based on the camera's dimensions.
The camera's aspect ratio. This value is always in range (0; inf) unless the dimensions are invalid (e.g. 0 width or height, NaN resolution, etc)
Implements Camera.
◆ BackgroundColor()
◆ BackgroundMaterial()
virtual MaterialPtr BackgroundMaterial ( ) const
Background material of this camera
◆ CreateRenderTexture()
◆ CreateRenderWindow()
Reimplemented from BaseCamera< Ogre2Sensor >.
Reimplemented from Ogre2Node.
◆ DestroyRenderTexture()
void DestroyRenderTexture ( )
◆ HFOV()
virtual math::Angle HFOV ( ) const
Implements Camera.
◆ OgreCamera()
virtual Ogre::Camera* OgreCamera ( ) const
Implements Ogre2ObjectInterface.
◆ ProjectionMatrix()
Camera projection matrix
Implements Camera.
◆ Render()
virtual void Render ( )
Implements Camera.
◆ RenderTarget()
◆ RenderTextureGLId()
Texture Id of type GLuint.
Implements Camera.
◆ RenderTextureMetalId()
virtual void RenderTextureMetalId ( void *  _textureIdPtr) const
◆ SelectionBuffer()
Ogre2SelectionBuffer* SelectionBuffer ( ) const
◆ SetAntiAliasing()
◆ SetAspectRatio()
image_height /
image_width
◆ SetBackgroundColor()
◆ SetBackgroundMaterial()
virtual void SetBackgroundMaterial ( MaterialPtr  _material)
[in]_materialMaterial to set the background to
◆ SetFarClipPlane()
◆ SetHFOV()
◆ SetMaterial()
◆ SetNearClipPlane()
◆ SetProjectionMatrix()
◆ SetProjectionType()
virtual void SetProjectionType ( CameraProjectionType  _type)
SetProjectionMatrix
◆ SetSelectionBuffer()
virtual void SetSelectionBuffer ( )
◆ SetShadowsDirty()
void SetShadowsDirty ( )
◆ SetVisibilityMask()
[in]_maskVisibility mask
Implements Sensor.
◆ SyncOgreCameraAspectRatio()
void SyncOgreCameraAspectRatio ( )
◆ ViewMatrix()
Camera view matrix
Implements Camera.
◆ VisualAt()
virtual VisualPtr VisualAt ( const gz::math::Vector2i &  _mousePos)
◆ backgroundColor
◆ ogreCamera
◆ renderTexture
◆ selectionBuffer
Ogre2SelectionBuffer* selectionBuffer = nullptr
