Geometry Class Referenceabstract
#include <gz/rendering/Geometry.hh>
 Clone the geometry. More...
◆ ~Geometry()
virtual ~Geometry ( )
◆ Clone()
virtual GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implemented in BaseMesh< T >, BaseCapsule< T >, and BaseGeometry< T >.
◆ HasParent()
Implemented in Ogre2Geometry, and OgreGeometry.
Implemented in BaseMesh< T >, Ogre2Heightmap, OgreHeightmap, Ogre2Capsule, OgreCapsule, OgreText, OgreWireBox, Ogre2WireBox, OgreMarker, Ogre2Marker, OgreGrid, and Ogre2Grid.
◆ Parent()
the parent Visual
Implemented in BaseGeometry< T >, Ogre2Geometry, and OgreGeometry.
◆ RemoveParent()
virtual void RemoveParent ( )
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [1/2]
bool  _unique = true
Implemented in BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, BaseGeometry< T >, BaseGeometry< Ogre2Object >, and BaseGeometry< OgreObject >.
◆ SetMaterial() [2/2]
bool  _unique = true
Implemented in BaseGeometry< T >, BaseGeometry< Ogre2Object >, BaseGeometry< OgreObject >, BaseMesh< T >, BaseMesh< Ogre2Geometry >, BaseMesh< OgreGeometry >, Ogre2Heightmap, OgreHeightmap, Ogre2Capsule, OgreCapsule, OgreText, OgreWireBox, Ogre2WireBox, OgreMarker, Ogre2Marker, OgreGrid, and Ogre2Grid.
