BaseCapsule< T > Class Template Reference
Base implementation of a Capsule Geometry. More...
#include <BaseCapsule.hh>
| virtual | ~BaseCapsule () |
| virtual double | Length () const override |
| Get the length of the capsule. More... | |
| virtual double | Radius () const override |
| Get the radius of the capsule. More... | |
| virtual void | SetLength (double _length) override |
| Set the length of the capsule. More... | |
| virtual void | SetRadius (double _radius) override |
| Set the radius of the capsule. More... | |
Public Member Functions inherited from Capsule | |
| virtual | ~Capsule () |
| Destructor. More... | |
| virtual | ~Geometry () |
| virtual VisualPtr | Parent () const =0 |
| BaseCapsule () | |
Protected Attributes | |
| bool | capsuleDirty = false |
| Flag to indicate capsule properties have changed. More... | |
| double | length = 0.5 |
| Length of the capsule. More... | |
| double | radius = 0.5 |
| Radius of the capsule. More... | |
◆ BaseCapsule()
protected |
◆ ~BaseCapsule()
virtual |
◆ Clone()
overridevirtual |
◆ Length()
overridevirtual |
Implements Capsule.
◆ Radius()
overridevirtual |
Implements Capsule.
◆ SetLength()
overridevirtual |
Implements Capsule.
◆ SetRadius()
overridevirtual |
Implements Capsule.
◆ capsuleDirty
protected |
◆ length
protected |
◆ radius
protected |
