Geometry for a capsule shape. The APIs allow setting the capsule's radius and length directly which ensure that the the geometry remains the shape of a capsule. In comparison, if the size is changed via the parent Node's Set*Scale function, the capsule may become deformed. More...
#include <gz/rendering/Capsule>
| virtual | ~Capsule () |
| Destructor. More... | |
| virtual double | Length () const =0 |
| Get the length of the capsule. More... | |
| virtual double | Radius () const =0 |
| Get the radius of the capsule. More... | |
| virtual void | SetLength (double _length)=0 |
| Set the length of the capsule. More... | |
| virtual void | SetRadius (double _radius)=0 |
| Set the radius of the capsule. More... | |
| virtual | ~Geometry () |
| virtual VisualPtr | Parent () const =0 |
◆ ~Capsule()
virtual |
◆ Length()
pure virtual |
Implemented in BaseCapsule< T >.
◆ Radius()
pure virtual |
◆ SetLength()
pure virtual |
Implemented in BaseCapsule< T >, BaseCapsule< Ogre2Geometry >, and BaseCapsule< OgreGeometry >.
◆ SetRadius()
pure virtual |
