Ogre2Geometry Class Referenceabstract
Ogre2.x implementation of the geometry class. More...
#include <Ogre2Geometry.hh>
| virtual | ~Ogre2Geometry () |
| Destructor. More... | |
| virtual Ogre::MovableObject * | OgreObject () const =0 |
| Get the ogre object representing this geometry. More... | |
| virtual VisualPtr | Parent () const override |
Public Member Functions inherited from BaseGeometry< Ogre2Object > | |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique=true) override=0 |
| virtual | ~Geometry () |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2Geometry () | |
| Constructor. More... | |
| virtual void | SetParent (Ogre2VisualPtr _parent) |
| Set the parent of this ogre geometry. More... | |
Protected Member Functions inherited from BaseGeometry< Ogre2Object > | |
| BaseGeometry () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Init () |
| virtual void | Load () |
Protected Attributes | |
| Ogre2VisualPtr | parent |
| Parent visual. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2Geometry()
protected |
◆ ~Ogre2Geometry()
virtual |
◆ HasParent()
overridevirtual |
◆ OgreObject()
pure virtual |
- Returns
- Pointer to an ogre movable object
Implemented in Ogre2Mesh, Ogre2Heightmap, Ogre2Capsule, Ogre2Marker, Ogre2WireBox, and Ogre2Grid.
◆ Parent()
overridevirtual |
◆ SetParent()
protectedvirtual |
[in] _parent Parent visual
◆ parent
protected |
Parent visual.
