Ogre2Grid Class Reference
Ogre2 implementation of a grid geometry. More...
#include <Ogre2Grid.hh>
| virtual | ~Ogre2Grid () |
| Destructor. More... | |
| virtual void | Init () |
| virtual MaterialPtr | Material () const |
| virtual Ogre::MovableObject * | OgreObject () const |
| Get the ogre object representing this geometry. More... | |
| virtual void | PreRender () |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) |
Public Member Functions inherited from BaseGrid< Ogre2Geometry > | |
| virtual | ~BaseGrid () |
| virtual unsigned int | CellCount () const |
| Get the number of cells on a planar grid. More... | |
| virtual double | CellLength () const |
| Get the cell length. More... | |
| virtual void | Destroy () |
| virtual void | SetCellCount (const unsigned int _count) |
| Set the number of cells on a planar grid. More... | |
| virtual void | SetCellLength (const double _len) |
| Set the cell length in one direction. The cells are assumed to be square. More... | |
| virtual void | SetVerticalCellCount (const unsigned int _count) |
| Set the vertical cell count of the grid. This makes the grid 3D. More... | |
| virtual unsigned int | VerticalCellCount () const |
| Get the vertical cell count. More... | |
Public Member Functions inherited from Grid | |
| virtual | ~Grid () |
| virtual unsigned int | CellCount () const =0 |
| virtual double | CellLength () const =0 |
| virtual unsigned int | VerticalCellCount () const =0 |
| virtual | ~Geometry () |
Public Member Functions inherited from Ogre2Geometry | |
| virtual | ~Ogre2Geometry () |
| virtual VisualPtr | Parent () const override |
Public Member Functions inherited from BaseGeometry< Ogre2Object > | |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2Grid () | |
| Constructor. More... | |
| virtual void | SetMaterialImpl (Ogre2MaterialPtr _material) |
| Set material to grid geometry. More... | |
Protected Member Functions inherited from BaseGrid< Ogre2Geometry > | |
| BaseGrid () | |
Protected Member Functions inherited from Ogre2Geometry | |
| Ogre2Geometry () | |
| virtual void | SetParent (Ogre2VisualPtr _parent) |
| Set the parent of this ogre geometry. More... | |
Protected Member Functions inherited from BaseGeometry< Ogre2Object > | |
| BaseGeometry () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseGrid< Ogre2Geometry > | |
| unsigned int | cellCount |
| Number of cells in grid. More... | |
| double | cellLength |
| Length of a single cell. More... | |
| bool | gridDirty |
| Flag to indicate grid properties have changed. More... | |
| double | heightOffset |
| vertical offset of the XY plane from origin More... | |
| unsigned int | verticalCellCount |
| Number of cells in vertical direction. More... | |
Protected Attributes inherited from Ogre2Geometry | |
| Ogre2VisualPtr | parent |
| Parent visual. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2Grid()
protected |
◆ ~Ogre2Grid()
virtual |
◆ Init()
virtual |
◆ Material()
virtual |
◆ OgreObject()
virtual |
- Returns
- Pointer to an ogre movable object
Implements Ogre2Geometry.
◆ PreRender()
virtual |
Reimplemented from BaseGrid< Ogre2Geometry >.
◆ SetMaterial()
virtual |
◆ SetMaterialImpl()
protectedvirtual |
[in] _material Ogre material.
