#include <BaseGrid.hh>
virtual ~BaseGrid ()
virtual unsigned int CellCount () const
 Get the number of cells on a planar grid. More...
virtual double CellLength () const
 Get the cell length. More...
virtual void Destroy ()
virtual void PreRender ()
virtual void SetCellCount (const unsigned int _count)
 Set the number of cells on a planar grid. More...
virtual void SetCellLength (const double _len)
 Set the cell length in one direction. The cells are assumed to be square. More...
virtual void SetVerticalCellCount (const unsigned int _count)
 Set the vertical cell count of the grid. This makes the grid 3D. More...
virtual unsigned int VerticalCellCount () const
 Get the vertical cell count. More...
virtual ~Grid ()
 Clone the geometry. More...
 BaseGrid ()
unsigned int cellCount = 10u
 Number of cells in grid. More...
double cellLength = 1.0
 Length of a single cell. More...
bool gridDirty = false
 Flag to indicate grid properties have changed. More...
double heightOffset = 0.0
 vertical offset of the XY plane from origin More...
unsigned int verticalCellCount = 0
 Number of cells in vertical direction. More...
template<class T>
class gz::rendering::BaseGrid< T >
🔗BaseGrid()
BaseGrid
🔗~BaseGrid()
~BaseGrid
🔗CellCount()
unsigned int CellCount ( ) const
Number of cells
Implements Grid.
🔗CellLength()
double CellLength ( ) const
The cell length
Implements Grid.
🔗Destroy()
void Destroy ( )
🔗PreRender()
void PreRender ( )
Reimplemented in OgreGrid, and Ogre2Grid.
🔗SetCellCount()
void SetCellCount ( const unsigned int  _count)
[in]_countThe number of cells
Implements Grid.
🔗SetCellLength()
void SetCellLength ( const double  _len)
[in]_lenThe cell length
Implements Grid.
🔗SetVerticalCellCount()
void SetVerticalCellCount ( const unsigned int  _count)
[in]_countNumber of cells in vertical direction.
Implements Grid.
🔗VerticalCellCount()
unsigned int VerticalCellCount ( ) const
The vertical cell count.
Implements Grid.
🔗cellCount
🔗cellLength
🔗gridDirty
🔗heightOffset
🔗verticalCellCount
