Ogre2Capsule Class Reference
Ogre 2.x implementation of a Capsule Geometry. More...
#include <Ogre2Capsule.hh>
| virtual | ~Ogre2Capsule () |
| Destructor. More... | |
| virtual MaterialPtr | Material () const override |
| virtual Ogre::MovableObject * | OgreObject () const override |
| Get the ogre object representing this geometry. More... | |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) override |
Public Member Functions inherited from BaseCapsule< Ogre2Geometry > | |
| virtual | ~BaseCapsule () |
| virtual double | Length () const override |
| Get the length of the capsule. More... | |
| virtual double | Radius () const override |
| Get the radius of the capsule. More... | |
| virtual void | SetLength (double _length) override |
| Set the length of the capsule. More... | |
| virtual void | SetRadius (double _radius) override |
| Set the radius of the capsule. More... | |
Public Member Functions inherited from Capsule | |
| virtual | ~Capsule () |
| virtual double | Length () const =0 |
| virtual double | Radius () const =0 |
| virtual | ~Geometry () |
Public Member Functions inherited from Ogre2Geometry | |
| virtual | ~Ogre2Geometry () |
| virtual VisualPtr | Parent () const override |
Public Member Functions inherited from BaseGeometry< Ogre2Object > | |
| virtual | ~Ogre2Object () |
| virtual | ~BaseObject () |
| Ogre2Capsule () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseCapsule< Ogre2Geometry > | |
| BaseCapsule () | |
Protected Member Functions inherited from Ogre2Geometry | |
| Ogre2Geometry () | |
| virtual void | SetParent (Ogre2VisualPtr _parent) |
| Set the parent of this ogre geometry. More... | |
Protected Member Functions inherited from BaseGeometry< Ogre2Object > | |
| BaseGeometry () | |
| Ogre2Object () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseCapsule< Ogre2Geometry > | |
| bool | capsuleDirty |
| Flag to indicate capsule properties have changed. More... | |
| double | length |
| Length of the capsule. More... | |
| double | radius |
| Radius of the capsule. More... | |
Protected Attributes inherited from Ogre2Geometry | |
| Ogre2VisualPtr | parent |
| Parent visual. More... | |
| Ogre2ScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ Ogre2Capsule()
protected |
◆ ~Ogre2Capsule()
virtual |
◆ Destroy()
overridevirtual |
Reimplemented from BaseGeometry< Ogre2Object >.
◆ Init()
overridevirtual |
◆ Material()
overridevirtual |
◆ OgreObject()
overridevirtual |
- Returns
- Pointer to an ogre movable object
Implements Ogre2Geometry.
◆ PreRender()
overridevirtual |
◆ SetMaterial()
overridevirtual |
