OgreCapsule Class Reference
Ogre 2.x implementation of a Capsule Visual. More...
#include <OgreCapsule.hh>
| virtual | ~OgreCapsule () |
| Destructor. More... | |
| virtual MaterialPtr | Material () const override |
| virtual Ogre::MovableObject * | OgreObject () const override |
| virtual void | SetMaterial (MaterialPtr _material, bool _unique) override |
Public Member Functions inherited from BaseCapsule< OgreGeometry > | |
| virtual | ~BaseCapsule () |
| virtual double | Length () const override |
| Get the length of the capsule. More... | |
| virtual double | Radius () const override |
| Get the radius of the capsule. More... | |
| virtual void | SetLength (double _length) override |
| Set the length of the capsule. More... | |
| virtual void | SetRadius (double _radius) override |
| Set the radius of the capsule. More... | |
Public Member Functions inherited from Capsule | |
| virtual | ~Capsule () |
| virtual double | Length () const =0 |
| virtual double | Radius () const =0 |
| virtual | ~Geometry () |
Public Member Functions inherited from OgreGeometry | |
| virtual | ~OgreGeometry () |
| virtual bool | HasParent () const |
| virtual VisualPtr | Parent () const |
Public Member Functions inherited from BaseGeometry< OgreObject > | |
Public Member Functions inherited from OgreObject | |
| virtual | ~OgreObject () |
| virtual | ~BaseObject () |
| OgreCapsule () | |
| Constructor. More... | |
Protected Member Functions inherited from BaseCapsule< OgreGeometry > | |
| BaseCapsule () | |
Protected Member Functions inherited from OgreGeometry | |
| OgreGeometry () | |
| virtual void | SetParent (OgreVisualPtr _parent) |
Protected Member Functions inherited from BaseGeometry< OgreObject > | |
| BaseGeometry () | |
Protected Member Functions inherited from OgreObject | |
| OgreObject () | |
| BaseObject () | |
| virtual void | Load () |
Protected Attributes inherited from BaseCapsule< OgreGeometry > | |
| bool | capsuleDirty |
| Flag to indicate capsule properties have changed. More... | |
| double | length |
| Length of the capsule. More... | |
| double | radius |
| Radius of the capsule. More... | |
Protected Attributes inherited from OgreGeometry | |
| OgreVisualPtr | parent |
Protected Attributes inherited from OgreObject | |
| OgreScenePtr | scene |
| unsigned int | id |
| std::string | name |
◆ OgreCapsule()
protected |
◆ ~OgreCapsule()
virtual |
◆ Destroy()
overridevirtual |
Reimplemented from BaseGeometry< OgreObject >.
◆ Init()
overridevirtual |
◆ Material()
overridevirtual |
◆ OgreObject()
overridevirtual |
Implements OgreGeometry.
◆ PreRender()
overridevirtual |
◆ SetMaterial()
overridevirtual |
