#include <BaseMesh.hh>
virtual ~BaseMesh ()
 Clone the geometry. More...
 Set the mesh's descriptor. More...
virtual ~Mesh ()
 BaseMesh ()
virtual SubMeshStorePtr SubMeshes () const =0
MeshDescriptor meshDescriptor
bool ownsMaterial = false
◆ BaseMesh()
BaseMesh
◆ ~BaseMesh()
~BaseMesh
◆ Clone()
GeometryPtr Clone ( ) const
Clone the geometry.
The cloned geometry.
Implements Geometry.
◆ Descriptor()
const MeshDescriptor & Descriptor ( ) const
The mesh's mesh descriptor
Implements Mesh.
void Destroy ( )
Reimplemented in Ogre2Mesh, and OgreMesh.
◆ HasSkeleton()
bool HasSkeleton ( ) const
True if the mesh has skeleton
Implements Mesh.
◆ HasSubMesh()
bool HasSubMesh ( ConstSubMeshPtr  _subMesh) const
[in]_subMeshSub-mesh in question
True if has given sub-mesh
Implements Mesh.
◆ HasSubMeshName()
bool HasSubMeshName ( const std::string &  _name) const
[in]_nameName of sub-mesh in question
True if has sub-mesh with given name
Implements Mesh.
void PreRender ( )
◆ SetDescriptor()
void SetDescriptor ( const MeshDescriptor &  _desc)
[in]_descThe new mesh descriptor
Implements Mesh.
◆ SetMaterial() [1/2]
bool  _unique = true
◆ SetMaterial() [2/2]
bool  _unique = true
void SetSkeletonAnimationEnabled ( const std::string &  _name,
bool  _enabled,
bool  _loop = true,
float  _weight = 1.0
[in]_nameName of animation
Implements Mesh.
void SetSkeletonLocalTransforms ( const std::map< std::string, math::Matrix4d > &  _tfs)
  • Map holding:
    • Skeleton node names
Implements Mesh.
◆ SetSkeletonWeights()
void SetSkeletonWeights ( const std::unordered_map< std::string, float > &  _weights)
  • Map holding:
    • Weight the skeleton nodes
Implements Mesh.
◆ SkeletonAnimationEnabled()
bool SkeletonAnimationEnabled ( const std::string &  _name) const
Implements Mesh.
◆ SkeletonLocalTransforms()
std::map< std::string, math::Matrix4d > SkeletonLocalTransforms ( ) const
  • Map holding:
Implements Mesh.
◆ SkeletonWeights()
std::unordered_map< std::string, float > SkeletonWeights ( ) const
  • Map holding:
Implements Mesh.
◆ SubMeshByIndex()
SubMeshPtr SubMeshByIndex ( unsigned int  _index) const
[in]_indexIndex of sub-mesh
The sub-mesh at the given index
Implements Mesh.
◆ SubMeshByName()
SubMeshPtr SubMeshByName ( const std::string &  _name) const
The sub-mesh with the given name
Implements Mesh.
◆ SubMeshCount()
unsigned int SubMeshCount ( ) const
The sub-mesh count
Implements Mesh.
◆ SubMeshes()
protectedpure virtual
◆ UpdateSkeletonAnimation()
void UpdateSkeletonAnimation ( std::chrono::steady_clock::duration  _time)
Implements Mesh.
◆ material
◆ meshDescriptor
◆ ownsMaterial
