#include <OgreLightVisual.hh>
virtual ~OgreLightVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre. More...
- Public Member Functions inherited from BaseLightVisual< OgreVisual >
virtual ~BaseLightVisual ()
std::vector< gz::math::Vector3d > CreateVisualLines ()
 Get inner angle. More...
 Get outer angle. More...
virtual void SetOuterAngle (double _innerAngle) override
 set type of the light More...
virtual ~LightVisual ()
 Descructor. More...
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreLightVisual ()
- Protected Member Functions inherited from BaseLightVisual< OgreVisual >
 BaseLightVisual ()
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseLightVisual< OgreVisual >
bool dirtyLightVisual
double innerAngle
double outerAngle
LightVisualType type
 Type of light visual. More...
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreLightVisual()
OgreLightVisual ( )
◆ ~OgreLightVisual()
virtual ~OgreLightVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseLightVisual< OgreVisual >.
Implements Visual.
◆ OgreObject()
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
