Light Class Referenceabstract
Represents a light source in the scene graph. More...
#include <gz/rendering/Light.hh>
virtual ~Light ()
◆ ~Light()
virtual ~Light ( )
◆ AttenuationConstant()
Implemented in Ogre2Light, and OgreLight.
◆ AttenuationLinear()
The attenuation linear value
◆ AttenuationQuadratic()
◆ AttenuationRange()
The attenuation range
◆ CastShadows()
◆ DiffuseColor()
The diffuse color
◆ Intensity()
virtual double Intensity ( ) const
The light intensity
◆ SetAttenuationConstant()
Implemented in BaseLight< T >, BaseLight< Ogre2Node >, BaseLight< OgreNode >, Ogre2Light, and OgreLight.
◆ SetAttenuationLinear()
◆ SetAttenuationQuadratic()
◆ SetAttenuationRange()
◆ SetCastShadows()
◆ SetDiffuseColor() [1/2]
[in]_colorNew diffuse color
◆ SetDiffuseColor() [2/2]
virtual void SetDiffuseColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
Implemented in BaseLight< T >, BaseLight< Ogre2Node >, and BaseLight< OgreNode >.
◆ SetIntensity()
virtual void SetIntensity ( double  _intensity)
[in]_intensityNew light intensity
◆ SetSpecularColor() [1/2]
[in]_colorNew specular color
◆ SetSpecularColor() [2/2]
virtual void SetSpecularColor ( double  _r,
double  _g,
double  _b,
double  _a = 1.0
[in]_rRed value
[in]_gGreen value
[in]_bBlue value
[in]_aAlpha value
◆ SpecularColor()
The specular color
