#include <OgreCOMVisual.hh>
virtual ~OgreCOMVisual ()
void CreateVisual ()
 Create the Light Visual in Ogre. More...
virtual VisualPtr SphereVisual () const override
 Get the sphere visual. More...
- Public Member Functions inherited from BaseCOMVisual< OgreVisual >
virtual ~BaseCOMVisual ()
virtual gz::math::Pose3d InertiaPose () const override
 Get the inertia pose. More...
virtual double Mass () const override
 Get the mass of the parent. More...
virtual void SetMass (double _mass) override
 Set the mass of the parent. More...
- Public Member Functions inherited from COMVisual
virtual ~COMVisual ()
virtual gz::math::Pose3d InertiaPose () const =0
virtual double Mass () const =0
virtual ~OgreVisual ()
virtual ~BaseVisual ()
virtual ~OgreNode ()
 OgreCOMVisual ()
- Protected Member Functions inherited from BaseCOMVisual< OgreVisual >
 BaseCOMVisual ()
double SphereRadius () const
 Get the radius of the CoM sphere. More...
 OgreVisual ()
 BaseVisual ()
 OgreNode ()
- Protected Attributes inherited from BaseCOMVisual< OgreVisual >
bool dirtyCOMVisual
 Flag to indicate parent properties have changed. More...
gz::math::Pose3d inertiaPose
 Inertia pose in parent frame. More...
double mass
 Parent mass. More...
std::string parentName
 Parent visual name. More...
uint32_t visibilityFlags
bool wireframe
OgreNodeStorePtr children
OgreNodePtr parent
◆ OgreCOMVisual()
OgreCOMVisual ( )
◆ ~OgreCOMVisual()
virtual ~OgreCOMVisual ( )
◆ CreateVisual()
void CreateVisual ( )
Reimplemented from BaseCOMVisual< OgreVisual >.
Implements Visual.
◆ OgreObject()
◆ SetMaterial()
bool  _unique
Implements Visual.
◆ SetMaterialImpl()
[in]_materialOgre material.
◆ SphereVisual()
Pointer to the sphere visual
Implements COMVisual.
