Base implementation of a wireframe box. More...
#include <BaseWireBox.hh>
virtual ~BaseWireBox ()
virtual gz::math::AxisAlignedBox Box () const
 Get the wireframe box. More...
virtual void Destroy ()
virtual void PreRender ()
virtual void SetBox (const gz::math::AxisAlignedBox &_box)
 Set the axis aligned box. More...
- Public Member Functions inherited from WireBox
virtual ~WireBox ()
 Clone the geometry. More...
 BaseWireBox ()
- Protected Member Functions inherited from WireBox
 WireBox ()
gz::math::AxisAlignedBox box
bool wireBoxDirty = false
 Flag to indicate WireBox properties have changed. More...
template<class T>
class gz::rendering::BaseWireBox< T >
◆ BaseWireBox()
BaseWireBox
◆ ~BaseWireBox()
~BaseWireBox
◆ Box()
gz::math::AxisAlignedBox Box ( ) const
The wireframe box.
Implements WireBox.
void Destroy ( )
void PreRender ( )
Reimplemented in OgreWireBox, and Ogre2WireBox.
◆ SetBox()
void SetBox ( const gz::math::AxisAlignedBox &  _box)
[in]_boxThe axis aligned box
Implements WireBox.
◆ box
◆ wireBoxDirty
